Newbie with an LS9 Engine
My name is Sam and this is my first post here. Nice to see a site like this with all the resources and knowledge. I am a motorcycle mechanic by trade but I am just learning about my Chevy. It is a 2wd 1970 3/4 ton with less than 150,000 miles on it. It has a 411 diff and a 3 spd auto in it. I'd like to find out a little more about the engine. It is the original LS9.
![]() Join Date: Sep 2012
Re: Newbie with an LS9 Engine
Not sure about the power a LS9 makes. But am curious as to how that 3spd transmission is at 100kph? Are your RPM's pretty high? With 4.11:1 gears in the rearend, I would probably want and overdrive transmission behind that LS9.
Not sure which LS9 you have.
The original LS9 was a 350 cu in V8, developing 160 hp and 245 Ft/lbs of torque. The Gen IV LS9 is a supercharged 6,162 cc (6.162 L; 376.0 cu in) engine, based on the LS3; the LS7 block was not used due to the higher cylinder pressures created by the supercharger requiring the thicker cylinder walls of the LS3. Cylinder dimensions are now 4.06 in (103 mm) bore and 3.62 in (92 mm) stroke. It is equipped with an Eaton four-lobe Roots type supercharger and has a compression ratio of 9.1:1. Power output is rated 638 bhp (476 kW) at 6500 rpm and 604 lb·ft (819 N·m) at 3800 rpm. |
Haha, I wish mine was supercharged! It's the original 1970's version.
#5 | |
The factory crate ls3 I'm gonna put in a 2 wheel drive k5 is something like 420 horse with the factory tune ECM So when I get bored and throw in a supercharge I'm gonna gain 200 horse. I haven't even looked at the specs but I was guessing 100 horse. I've been out of the hot rod world for a long time. What gm rear end is gonna hold up to that? Or do I just go with the ford 9" and call it a day. Posted via Mobile Device
Ed will be known as the Tiger Woods of the integration business |
#6 | |
Posted via Mobile Device |
#7 | |
Posted via Mobile Device Posted via Mobile Device |
I've heard talk about 325 hp 350's, I was hoping it was one of them. My wife's Z-24 makes 165 lol.
#9 | |
![]() Join Date: Jul 2013
And yes the LS3 does make over 400hp.The LS3 E-rod is rated at like 420, the LSA makes over 500 and the LS9 makes well over 600. All with great drivability and reliability.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
It feels more like that kinda HP despite what it looks like.
http://[URL=http://s824.photobucket.com/user/SmokinSam/media/MasterBateson002.jpg.html] ![]() |
