Old 08-13-2013, 12:58 PM   #1
85/Silverado
85/Silverado's Avatar
Interior Install Help
This is my order for my Silverado and the strap that you pull the door closed with comes in Black and my Interior is Red, My question is what do you use to paint this plastic interior parts? Does someone make the paint or stain?
Also how hard is it to install the new carpet?
Can one person replace the bumpers, Or do I need someone to help?
I'm sure there will be a lot more questions.
Thanks Guys
Jack
85/Silverado is offline   Reply With Quote
Old 08-13-2013, 01:08 PM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Interior Install Help
SEM has prducts to paint the interior parts,
It is pretty easy to install the carpet, just remove seat, seta belts, kick panels, and rocker panel trim peices, most after market carpet is preshaped so it should drop right in, then just replace everything. One tip install the bolts for the seat and set belts, makes it easy find the bolt holes to cut holes in the carpet for the bolts to go through.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 08-13-2013, 01:14 PM   #3
TexasJeff
TexasJeff's Avatar
This is the paint I used for my interior parts.
http://www.semproducts.com/
Carpet is easy to install, one tip, after you remove the seat and seat belts reinstall the bolts to find were to cut the holes, makes it alot easy.
With a good floor jack you should be able to install bumpers with one person, Just install most of the brackets, and put a towel on the floor jack so you dont scratch the chrome.
TexasJeff
Old 08-13-2013, 01:29 PM   #4
JWall
Frequent Flyer
JWall's Avatar
SEM is the way to go.
Easy to use, it covers well, just prep & clean your pieces very well before painting.
- Justin
1 Owner 1976 SWB
Old 08-13-2013, 02:11 PM   #5
JWall
Frequent Flyer
JWall's Avatar
Oh and as far as the carpet... get the carpet out of the box and laying flat as soon as you get it. Then if possible lay it out in the sun some too.
You may have to trim the carpet a little on the side by the door sills so just be careful not to trim too much.
I just did all new interior (including painting with SEM Paint & new carpet) in my 76 so you might flip thru the first few pages of this thread for a few pics.... http://67-72chevytrucks.com/vboard/s...d.php?t=569216
- Justin
1 Owner 1976 SWB
Old 08-13-2013, 03:34 PM   #6
kjc292
kjc292's Avatar
havent replaced my rear bumper, but the front bumper i just sat on the ground like im going to do a sit up(without laying my upper half down) go to bolts in and nuts just finger tight. then went from there. took me about 15 minutes to take old one and off and put new one on. im redoing my interior too. found rock auto had better prices.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 08-13-2013, 06:39 PM   #7
Skunksmash
Skunksmash's Avatar
Does Rockauto have interior parts?
Also, to the OP. Your pic looks good, but 2 things you might consider:
1. Did they ever come up with a fix, or an update, for those door pull straps? If not, consider that in the end, they will end up just like that old ones. Broken and dilapidated. You might want to just get the delete panel.
2. If you can afford it, and it looks like you can, get your carpet installed at an auto-upholstery shop. It was recommended to me here, that I should do that instead of getting a pre-cut pile. Or whatever they call it. You never can get the pre-cut stuff to lay down like factory, and the upholstery shop will get it all perfect. I too used AAC carpets from my truck, and now I wish I hadn't.
3. Don't waste your time with Coverlay brand dash covers. I've tried them, they don't work. They do not make them large enough for you to ever get them to fit right on a typically old, cracked, warped dash. I know you just got one of those carpet ones, but eventually everybody starts looking for a better looking alternative.
Skunksmash is offline   Reply With Quote
Old 08-13-2013, 10:45 PM   #8
05duramaxhd
Dash and door panels can be covered by Connor Sweet. He does amazing work. He made me new map pockets and pull straps
05duramaxhd is offline   Reply With Quote
Old 08-14-2013, 08:38 AM   #9
Skunksmash
Skunksmash's Avatar
He have a website? What state is he in?
Old 08-14-2013, 08:57 AM   #10
05duramaxhd
Connor Sweet crsweet@sbcglobal.net
is his email he is in CA
he has a photobucket account with lots of pics
Search the member list for crsweet91
Old 08-15-2013, 11:58 AM   #11
Skunksmash
Skunksmash's Avatar
Is that someone who is so good, that people often mail him stuff? If not I need a guy like him in TX.
Old 08-15-2013, 06:53 PM   #12
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Connor is the best. He did two interiors for me that I mailed to him in California from me in Edmonton, Canada.
I 100% vouch for him.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 08-16-2013, 07:57 AM   #13
85/Silverado
Does anyone know If the interior colors that you order from LMC are original to that year? My interior is a Burgundy color but I notice the color is listed as Red on the order form.
Old 08-16-2013, 08:53 AM   #14
85/Silverado
I wish the wife would let me just buy this one.
http://www.seautoinc.com/detail-1985...d-6974454.html
Old 08-16-2013, 09:28 AM   #15
Skunksmash
Skunksmash's Avatar
You've got to be careful with LMC. Sometimes its bang on, sometimes its off by a lot. And they'll sell you the wrong color and tell you its the right one, in order to try and convince you its right, and that you should just buy it. They'll sell only 3 different colors of something, for example, and claim that those 3 colors are correct and will match your truck. Wrong. For me, LMC is a last resort. They're not nearly as customer oriented as some of the other ones out there.
