paper or plastic?
front driveline
Hey guys, been around the 67-87 Chevy trucks for a long time but have never had a 4x4. What's the deal with this front driveline in the picture? Is it a crude spacer? what should be there?
This is on a 1986 stock (no lift) 4x4
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
Re: front driveline
Yea, I'd say that's a crud spacer alright.. I would say he probably didn't have short enough bolts and needed the space provided by the over sized nuts slipped over the unthreaded portion of the bolts to allow the bolts to tighten, if tightened without the over size nuts the threads would bottom out before the flanges made contact..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: front driveline
The flange should mate up with the output. What you have pictured there is just...stupid.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
Re: front driveline
Redneck spacer and get that fixed before you drive it.
Too many projects
Re: front driveline
Redneck spacer and more likely to break bolts.
When torqued properly the bolts don't actually take the rotational torque of the driveshaft, the friction between the mating surfaces of the flanges transfer the torque. With nuts in there there is no friction and therefore all rotational stress is through those four small bolts. AKA no bueno.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
