Stock Gages?
My truck just came with the basic gages. Speedo, Fuel, and idiot lights. But the guy I bought my truck from gave me a whole box of extras. Im not sure where all this stuff came from, but its obviously not from my truck.
He gave me 2 extra full gage clusters, and the other two have actual gages for temp and oil pressure (I need to double check and see if one has a tach. Im at work and cant remember off hand). Is there an easy way to check to see if one of these clusters is fully functional? Or do I have to pull mine out and just hope for the best? What all will I need to change to hook up the temp and oil pressure gages? Both sets of gages do have the electrical strip along the back.
71 swb 350/4sp manual 5/7 static drop |
the boat guy
Re: Stock Gages?
Temp sending unit and an oil line.
Its probably quicker and easier to swap clusters than to test the gages. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: Stock Gages?
My truck came with the basic set up too but I've wanted to put the "full guage" package into it for years! One day.....
Re: Stock Gages?
Its not a plug and play swap. The wires in the harness connector need to be moved around for the gauges to work correctly and IIRC not doing it will burn something out. Try the search button for details on a cluster swap.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
