Old 07-04-2003, 01:07 PM   #1
low 84
low 84's Avatar
fuel pump return line?
ok i'm changing my truck over from the stock style pump that uses a return line to a holley mechanical pump. one of the hard lines that runs from the tank to the pump is big and one is small. am i right in guessing the big line is the feed and the small line is the return?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 07-04-2003, 01:51 PM   #2
BigRed
Sounds right to me. However I'm not positive. It makes no sense that they would run the larger line as the return.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 07-04-2003, 02:50 PM   #3
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
if you only have two lines running from the tanks, then you probably dont have a return line. The smaller one is probably the vent. Does it go directly to the fuel pump or to the charcoal canister?
Is your stock fuel pump a 2 port or 3 port? If its a 3 port, it should have a return. 2 ports are just input from tank, and output to carb.
mike
mike reeh is offline   Reply With Quote
Old 07-04-2003, 07:46 PM   #4
low 84
low 84's Avatar
mike
yes i have a three port pump, and inlet outlet and return, i also had the vent line which i removed becuase i'm not running any emmsions equipment. the small line that connects to the fuel pump is the same size as the vent line was and then there is a bigger line goin to the fuel pump aswell. so i'm guessing this is the feed which is the only one i need to keep?
'05 1500 Crew Cab
RIP
Old 07-04-2003, 08:04 PM   #5
mike reeh
mike reeh's Avatar
Hmm the two smaller lines are the same size? I find that hard to beleive. There should be a 3/8" which is feed, 5/16" which is the vent and believe it or not the 1/4" is the return. Things may have changed slightly over the years though. This IS general motors we're talking about, and just about anything is possible.
mike
Old 07-04-2003, 11:29 PM   #6
low 84
low 84's Avatar
mabey i mistaked the 3/8 and 5/16 as the same size. but the 1/4 is the return? i just cut off the wrong line then, lol
'05 1500 Crew Cab
RIP
