WTB 72 power steering pump brackets
Need to buy the power steering pump brackets for a 72 pickup.
Thanks John Waco, Texas Posted via Mobile Device |
Just like to part out trucks!!
Re: WTB 72 power steering pump brackets
I have the lower cast one but not the steel back one, if anyone has the steel one you'd have a set
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Cluster King
![]() Join Date: Nov 2012
It is my understanding that the PS brackets are the same for a long water pump and a short pump. If this is true, I have an extra set that is blasted and painted black, ready to install.
I would take $40.00 for both or $25.00 for each piece shipped if I (someone/anyone) can confirm if they are the same. I bought the set for my 72 because it has a long water pump and I want to change to a short. EDIT: Give teeitup the opportunity for the sale of the cast bracket first. |
Thanks for the replies here is a picture off what i am told is a 72 with a 350 short water pump.
I am not 100% sure because I have never seen a picture of both brackets. |
![]() Join Date: Aug 2003
Long/short water pump are NOT same.
Cluster King
I am not home now but I will be there this weekend and I will check what I have compared to the ones already on my truck. If there is no difference, then I will offer them up and post photos.
Until then, if you find what you need elsewhere, no worries. Good Luck |
John, the ones in your pic are SWP brackets for our years, as Uncle said LWP brackets are different. As I said I have the cast one is all. Thanks Randy
Thanks for all the help guys I am going to see if I can buy this set. Then I can install my Captainfab power steering pump bracket this is all going on my 66.
Cluster King
I have done a little research on this and discovered the following. If you have a long water pump set up on a 1967-1972 chevy pick up, it is incorrect. That does not mean it will not work but all trucks with 350 engines had a short waterpump set up from the factory until 1973 when they changed. also in 1973, the cast portion of the p/s bracket was eliminated and all pieces of the brackets were stamped steel.
The reason I questioned long water pump verses short water pump is that my 1972 has a 1978 engine with a long water pump and alternator on the passenger side. As I mentioned, the correct set up is a short water pump with alternator on drivers side. What confused me is although I have a long water pump set up, I have a short style p/s bracket set up. I am willing to bet, I could replace my pump and brackets from a 1973 + engine and it would work just fine. I am not convinced that it is a long vs short problem more than it is a 1972 vs 1973 problem. I hope this makes since. If you still need brackets Jim, I have them also for sale. Good Luck. |
I have the steel one your looking for I think. Here is the picture of it, let me know if you want it.
Posted via Mobile Device Posted via Mobile Device
Scott |
Thanks for all the information and offers to sell the pieces separately, i will know by tomorrow if I am able to buy the one I pictured in the earlier post.
