Old 08-14-2013, 12:13 AM   #1
1969shortbed6.0
Ideal backspacing?
I have a c10 lowered 2.5 inches in the front and 3 inches in the back. I am planning to run a 18x8 wheel with 255/55-18 tires front and back. What is a safe backspacing? Does anybody have a similar setup? Any help would be greatly appreciated!! Thanks Joe
1969shortbed6.0 is offline   Reply With Quote
Old 08-14-2013, 07:53 AM   #2
CC69Rat
CC69Rat's Avatar
Re: Ideal backspacing?
When I hear questions about an 18" wheel setup, the first truck I think about is 'SactoJim' .. he is a forum member too.
http://67-72chevytrucks.com/vboard/s...d.php?t=548242
Check out the article on CCT, post #1. This is by far the best 18" wheel setup I'm aware of. I love this truck. I think he might be a tad lower than 2.5/3 drop though.. but it would still look great IMO if you ran this same setup.
Do you know which rear end housing you have in your truck? There were two different housings available in these trucks. 67-69 were 1.5" more narrow than (late) 70-72 trucks. What I'm saying is if you use these same backspacing specs just make sure you have the same rear end housing he does or the backspacing will be way off. I'm not sure which housing he has...
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-14-2013, 07:56 AM   #3
Robznob11
Robznob11's Avatar
Im gonna guess its going to be 4 1/2 but if you post it in the suspension section im sure lolife will get you straight. He knows is stuff on dropped rides
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-14-2013, 10:43 AM   #4
1969shortbed6.0
I have the wider 57 inch rear end.
Old 08-14-2013, 02:45 PM   #5
Robznob11
Robznob11's Avatar
I run a 15x12 with 6.5 bs on narrow rear and it tucks perfect so a quick calculation tells me that a 8 wide with 3.25 bs would perfectly tuck on yours less bs would be out to far. So the real question is the front i bet you need at least 4 bs on front
LED TAILS
