66' power steering bracket
I currently have power steering but the previous owner didn't use the bracket plate he just put spacers, i searched and searched but i cant get an accurate answer cuz alot of the threads are old and dont match up with many companies, basically i want the bracket but want to minimize drilling what is a good company to purchase just the bracket from ?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 66' power steering bracket
I make and sell the power steering box adapter brackets, but you will have to drill 4 holes. But not knowing what the PO did, there may be welding needed to correct the previous install.
Well its mounted so wouldn't it match the holes on your bracket ?
60-66 Nut
Not necessarily. Not everyone mounts the steering box in the same location. My adapter plate comes with a template that locates the new steering box referenced from the holes for the original box. The other sellers of steering box plates, have you mount the box different than what I do.
Maybe I can make some measurments of the holes and the space between them and PM you
757,
If you currently have power steering, What is the problem? "If it ain't broke, don't fix it" Shorty |
1961 crewcab
capt. fabs brackets are perfect!
I have used 2 so far, super easy install!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
