Why dont I have heat?
I'm not real good with AC and heat. My blower works fine, low, medium, and high, but the air blowing is not warm. It's on the cooler side but not cold. AC works kind of. I need a new compressor. But no warm air. Any suggestions on where to start looking?
Thanks fellas -Andrew Posted via Mobile Device |
Cluster King
![]() Join Date: Nov 2012
Re: Why dont I have heat?
A couple of things come time mind:
Is the coolant level OK? How long do you let it run to check the heat? If the t-stat is stuck open it will take the engine a lot longer to get to operating temp. Also how is the engine temp? Is it at least 180 degrees? You should have a vacuum operated heater control valve if your truck has AC. Is there a vacuum source hooked to it and does it work? Have you felt the heater hoses, in and out? Are they both the same temp or is one hot and one cool? If you are unsure about the heater control valve, remove it and run a straight hose from the heater core to the engine and see what happens. If you have one hot and one cool in this case, the heater core may be plugged Is the cable for the heat door moving the heat door in it's complete motion? Sometimes the cables can get stretched and not move the heat door properly. Make sure the above mentioned items are good and then we can see what needs to happen. |
2WD Jimmy
Try the simple things first. Coolant level, also check the heater valve to see that its opening and not plugged.
![]() Join Date: Jan 2002
If you turn ur controls to defrost do you get any kind of antifreeze smell or an antifreeze residue on the inside of your windshield? That's what happened in my 78 ford and the heater core was shot.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Thanks for the info fellas. I'll look into it, and see what I can find out.
ive heard this mentioned before but why would a clogged heater core cause that? I havent experienced an anti freeze smell but i am re doing the heating system (it has never worked since i bought the truck) so i was just wondering
If you don't have a factory manual, download a copy here. There are lots of pages on the HVAC syatem.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
My heater core was leaking it wasn't plugged.
I am a Referee of life.
Also check to see that the vac hose is good to the vac operated valve.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Ok, so both or my hoses are hot, both valves are opened as far as they will go, still no heat. Coolant level is to the top, and no kinks in the vacuum tube. Cables seem fine. Am I down to the heater core? Is there anything I can do to test it before I start ripping the dash apart to get to it?
Thanks again fellas-Andrew |
lots of times the housing that the heater core is in is clogged with 40years of crap and no air can flow accross the heater core causing no heat// remove blower moter and stick hand in hole and start by pulling out quite a few handfulls of really really disgusting stuff tjen with air or garden hose start flushing the rest
20' Daredevil (Ret)
![]() Join Date: May 2003
It's starting to sound like a plugged heater core BUT if it's plugged, coolant wouldn't flow. Since both heater hoses are hot, coolant must be flowing through them. The hoses should get too hot to comfortably touch for the heater to work well. If they're not hot enough you may have a bad (or wrong, or missing) thermostat, or restricted flow (possibly caused by a partially plugged heater core).
#13 |
The Older Generation
Don't forget to clean the mouse nests out of your heater box.... .. That will probably cure your problem.You have to tear it apart to do that, or at least pull the blower motor like Cliff said. I use a vacuum to clean the "Stuff" out of it instead of my hands though... ![]() LockDoc
#14 | ||
Plan a day to pull the box your heater core is in. Have Lysol and/or bleach handy in case its a mouse. If its leaves, get some screen material to put between your cowl panel and the opening under there.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#15 |
Just a plugged core prolly wouldn't cause this, but a leaking one certainly would. That's what I had. The fluid leaks into the plenum carrying the odors right into the cab.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
#16 |
a heater core clogged with crap allows no flow of hot air as in no heat inside the cab of the truck/// and it is far more common cause of no heat than a ruptured leaking heater core
#17 |
I have been driving around for a couple weeks with out a cowl panel, while I'm gettijg it ready for paint. Think that could be an issue?
#18 |
I just cleaned a mouse nest out of mine. That blocked almost all the heat and most of the airflow too.
1990 Suburban Silverado 350, SM465 and 35" tires |
#19 |
Ok, so is replacing the heater core on and A/C truck the same as a non A/C truck? Iv never done one, so I really have no idea.
#20 |
Also, do I need to take off the inner fender to do it? It looks as if I can't get to all the bolts.
#21 | |
LockDoc
#22 | |
Read this old thread. http://67-72chevytrucks.com/vboard/s...d.php?t=223703 Read all the way through because some of it is for non AC units.... LockDoc
#23 |
how did you jump right to replacing the heater core???
from your initial post it sounds as if you have an air flow only problem and your heat solution is an easy no cost time only fix and you seem to b determined to try and throw money away by takin bad leaky advise???? is coolant level droping ?? smell of antifreeze?? a noticable leak at the core?? i did not see any of them symptoms listed????
| Bookmarks |
