Old 07-04-2003, 02:48 PM   #1
biddaboy
biddaboy's Avatar
Motor mount ? (pics)
Can any body tell by the pics if this is set up for V8 or I6 the frame had no engine when I got it Thanks biddaboy
biddaboy is offline   Reply With Quote
Old 07-04-2003, 02:49 PM   #2
biddaboy
biddaboy's Avatar
right
Old 07-04-2003, 03:23 PM   #3
SEVEND2
SEVEND2's Avatar
My 72 Mounts are the same (350 cid) (would say V-8)
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 07-04-2003, 04:21 PM   #4
krue
Designated A-hole!
krue's Avatar
Looks like the mounts on my 70 with a 350! So my guess is v-8 mounts!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-04-2003, 05:31 PM   #5
72MARIO
72MARIO's Avatar
Sorry dude thoes are 6Cly mounts. Yet they will work with a Small block.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-04-2003, 06:50 PM   #6
biddaboy
biddaboy's Avatar
Do I have to mount them in different holes for a V8 or are they OK where they are. Putting in 327 and powerglide Thanks biddaboy
Old 07-04-2003, 07:05 PM   #7
72MARIO
72MARIO's Avatar
They will be fine where they are. You will just not have as much fire wall clearence to the HEI.
2005 TAHOE DD
Old 07-04-2003, 08:21 PM   #8
67cst
i love summertime
67cst's Avatar
i think there is one more hole on each frame rail closer to the front end, cant you move em into those holes? that would make sense to be the v8 position
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 07-04-2003, 10:14 PM   #9
biddaboy
biddaboy's Avatar
I dont know I am new to this truck but I want to get it right the first time Thanks for any more info you guys can provide this is a great site Biddaboy
Old 07-04-2003, 10:19 PM   #10
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Like 72MARIO said, they will be ok and will work for a V8, only the engine will sit farther back, and a bit frther from the radiator, but nothing a fan shroud shoudln't help...heck even with out one over heating isn't a problem.
You could move them up the the V8 position and drill through the lower cross member.....well...thats what my parts truk had done to it.....my girlfreinds dad thought they were V8 mounts...as did I...I yanked em and cleaned them up then compared them to my mounts and such....and put two and two together and came to the conclusion that they were set up oon the V8 pos. and the cross member was drilled. My V8 is in the I6 pos....no problems....but good luck finding a driveshaft....had to have mine made. but no running problems....I just had a bad Crankshaft is all....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-04-2003, 10:28 PM   #11
SWINGSAX68
SWINGSAX68's Avatar
67cst....
the V8 mounts are shorter, and that hole you speak of is farther inside the frame than the I6
Below:
The red shows the V8 mount holes....the blue X kind of shows Where the I6 mounts would meet the crossmember if moved the the V8 position....and you could drill and bolt....I wouldn't.
the green circle May be for, I think, 1 ton 350 mounts or big block mounts....not sure....
I hope I helped..
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 07-04-2003, 10:31 PM   #12
SWINGSAX68
SWINGSAX68's Avatar
go to a salvage yard and pick up some engine mounts from a truck of our year or even a later model....I think 60 up until 87 will bolt right up. And the pads are cheap at like AutoZone and Oreillys
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 07-04-2003, 10:48 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
73-87 mounts are different.
By the way, if you have a short bed, and if you put your V8 in the right V8 position, and run a 700R4 trans, you can use a 81-87 short bed driveshaft without mods. They are everywhere in the junkyards, and it will do away with the 2 piece shaft deal too.
Old 07-05-2003, 01:42 AM   #14
biddaboy
biddaboy's Avatar
Hey you guys are great I hate to drag this post on for so long but there is one more thing I forgot to mention, i am using a crossmember out of a 1980 truck in my 69 frame,are the holes in the crossmembers both in the same place for the mounts Thanks again biddaboy
