Carpe manana
![]() ![]() Join Date: Dec 2010
Educate me: Need pics of an auxiliary battery actually attached to the OEM harness
Can't find the pics I need - all show an empty tray with no battery. I assume a side post battery - how does the harness positive wire attach to the battery?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Educate me: Need pics of an auxiliary battery actually attached to the OEM harnes
Batteries need to run in parallel; pos to pos. & neg to frame&chassis ground. This increases the overall amperage capacity of the system will keeping voltage constant.
Carpe manana
Thanks - I'm wondering what bolt/and or bracket secured the harness connection to the battery at both the pos and neg ends. What did GM do?
Cluster King
![]() Join Date: Nov 2012
Hey Pete,
Sorry I cannot help you with the battery wiring. I wanted to ask if your K10 is still for sale? Just thinking ![]() |
Carpe manana
Thanks for asking - yes, still for sale and it's a good truck at a fair price. PM if interested for more details. Best, Pete
Might very well have had a deep cycle battery that typically use wingnut lugs. The factory harness IIRC uses two ring terminals for battery attachment just like a boat. Let me look through my pictures.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-14-2013 at 08:46 PM. |
Carpe manana
Thanks Tim - you are correct on the harness attachments. The neg "harness" is more like an independent pigtail ground IIRC with two ring terminals. The pos harness connect is a red wire ring terminal.
Here sort through this. As I read it the earlier trucks used the dissimilar size side termianl bolts and the later trucks used the same 3/8" for bolts. In a nutshell, IMHO they were just the standard side terminal cable bolts used for the TP2 harness to battery connection. The camper schematic above (from the 72 service manual) is not the same as the 71 revision in the assembly manual, it (ASY M) clearly indicates a side terminal battery.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Carpe manana
As always, mucho appreciated Tim. I'm on the hunt for side terminal bolts 3/8" then - these must have threaded male ends. Funny how many pics of aux battery trays are on the site but I couldn't find one of an aux battery actually in use on a truck.
![]() Join Date: Feb 2011
This is on my 70
MusicMan70 1961 GMC Suburban |
Oops, wrong year.
Carpe manana
Here's a pic from a low mileage survivor truck that shows a tag attached to the aux harness at the battery connection - wish I knew what info was on that tag:
#13 |
Cluster King
Pete, the photo your posted is a local truck here in Michigan. If I need to, I will track it down and get some more info/photos for you. I am not sure if he still owns the truck but a board member from Michigan about 50 miles from me owned it. I believe he sold it but it is possible to still get info from the current owner, I would believe.
#14 | |
Carpe manana
#15 |
Carpe manana
Interesting tid bit for those adding this option to their trucks. GM installed the washer fluid bottle on the opposite (RH) fender. With the two j-blocks needed on this fender the bracket for the fluid bottle has to be mounted more rearward than normal. On the pic you can see one j-block is also slightly higher than the other. Using my K20 build as an example, in order to clear the inner fender it appears that the bracket has to be mounted higher than normal and you have to utilize a lower set of pre-existing holes in the bracket in order to get purchase on the fender unless GM had a different bracket on aux battery equipped trucks (I doubt it but who knows).
#16 |
The washer bottle relocation is shown clearly in the assembly manual.
It shows the bracket holes (on the right fender) are 5.06" aft of the production junction block. The second junction block is located 2.00" forward of and level with the production junction block.
#17 | |
Carpe manana
