08-14-2013, 07:02 PM | #1 |
67-72- dealer install a/c units
I have 2 dealer under dash units both have been dissasambled cleaned checked for leaks and put back together cleaned blower and all speeds work fine no parts missing nice vents asmps . Also have 2 compressor mounts 1 has beed blast and primed the other need to be cleaned both complete with all bolts and hardware asking $300.00 per underdash unit .. also have 2 v8 mount kit all parts plus shiping . I have 1 of these in my truck they work great better than factory i think
08-15-2013, 09:40 AM | #2 |
Re: 67-72- dealer install a/c units
Did this use quirk compressor? These were great serums and did make nice cold air! Those compressors were heavy but bullet proof!
Posted via Mobile Device |
08-15-2013, 11:44 AM | #3 |
I don't need the mounting stuff...are you willing to sell just the underdash unit? If so, please let me know your price...Thanks!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
08-15-2013, 12:21 PM | #4 | |
08-15-2013, 01:09 PM | #5 |
Is there any way to get some installation info/pics? Obviously these were designed for R12...how does one convert one of these to 134? Do you by chance know of an install thread on one of these systems? Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
08-15-2013, 02:50 PM | #6 |
no install instructions is is a easy install also all you need to convert to 134 is a retro kit about $20.00 to change it over
08-15-2013, 03:46 PM | #7 |
this is how it looks in my truck fits tight up to the dash THEY HAVE A REAL CLEAN LOOK
08-15-2013, 08:01 PM | #8 |
do you have to modify firewall to install and does this unit come with everything to install..a/c compressor..ect
08-15-2013, 09:29 PM | #9 |
Yes you will have to drill 2 holes in the fire wall 1 1/4 inch for the 2 a/c hoses and 1 small hole for the drain tube thats it also all the brackets are there to mount a compressor
08-15-2013, 11:05 PM | #10 |
does the compressor come with kit or is that a item I have to purchase seperatly.and if so what other items will I need to complete installation.thanks in advance.
08-16-2013, 12:20 AM | #11 |
I'll take the wood grain setup, shipping to Blaine WA, 98230
thx, Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
08-16-2013, 07:06 AM | #12 |
I'm very interested in the other one, but I would like to see some close-up pics. Also, can you tell me if the kick panel vent still opens with this unit installed? Thanks!
08-16-2013, 08:12 AM | #13 |
I know I should jump on this, but Im not sure about the install. My truck never had A/C. Other than whats in this kit what else will I need to install it in my truck
71 swb 350/4sp manual 5/7 static drop |
08-16-2013, 08:36 AM | #14 |
The kick panel vent is tight , as far as what other parts you will need is a/c compressor - drier - condensor - and hoses the hoses can be made up at any good radiator / a/c shop the condensor you can use a after market style or the factory type that is the kind i used as far as the inside unit just mount it and hook a power and groung wire
08-16-2013, 08:41 AM | #15 |
By saying the vent is tight, does that mean it doesn't open?
08-16-2013, 09:13 AM | #16 |
It will but not much
08-16-2013, 09:18 AM | #17 |
A few mor pictures
08-16-2013, 09:24 AM | #18 |
I'll take the non-wood grain unit. pm sent
08-16-2013, 04:57 PM | #19 |
I will have to get a shiping amount monday not sure if i want to put this in a box or build a wood box to protect the unit
08-18-2013, 11:37 AM | #20 |
A member asked about what type of campressor the brackets take it had a square york style but there is a company that makes a adapter to mount a sanden style compressor also
08-22-2013, 07:31 PM | #21 |
Looks like both inside units are sold and 1 bracket set
