Old 08-14-2013, 07:44 PM   #1
jd21476
jd21476's Avatar
How does the glovebox connect?
My 1973 K20 glovebox stays in fine and locks well but when I open it there is nothing holding it in. I can simply pull it out or let it drop to the floor if I wanted. What is it missing that holds it in place?
jd21476 is offline   Reply With Quote
Old 08-14-2013, 07:54 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How does the glovebox connect?
The hinge section on the bottom is broken.
Very common.
The entire plastic part of the glovebox is one piece. There is a flange on the bottom of it that's bolted to the lower edge of the dash with four screws. They break when they get old or get overextended. The fix is to buy a new glove box liner. Simple to replace but kind of pricy at nearly 50 bucks.
Old 08-14-2013, 10:31 PM   #3
esbstuff
Bad part is if the Parts label is in the glove box, its a pita to replace.
esbstuff is offline   Reply With Quote
Old 08-14-2013, 10:55 PM   #4
jd21476
jd21476's Avatar
Ok, cool thank you
Old 08-16-2013, 10:14 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
heat gun from the back softenes one enough to remove it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
