Old 08-14-2013, 10:26 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
New coil spring misaligned after installation
This past weekend, I installed a set of new upper and lower ball joints and coils in my 72 Cheyenne. I noticed, after I got it all put back together, that my driverside coil was sitting fine in the lower control arm, but a little off center where it goes up into the spring housing, more towards the tire. Could this spring center its self with a little cruise and maybe a speed bump, or will that cause damage? I suppose I could rent the compressor again, but i thought it wouldnt hurt to ask.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 08-14-2013, 10:46 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: New coil spring misaligned after installation
They will usually pop into place if you drive it a little. You'll hear it pop.
If it's stubborn, jack the truck up and let the suspension hang and use a prybar to pop it into the center of the upper pocket. With the suspension hanging, enough tension will be off the coil springs that you can usually pry it a bit.
99 times out of 100 though, they will seat themselves when you drive it.
Old 08-15-2013, 03:16 AM   #3
Square_78
Square_78's Avatar
Might be more of a loud BANG than a 'pop' though just so you know. Hahaha
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
