Old 08-15-2013, 12:21 AM   #1
jims72
79 4spd burb milage
Well now that I have got ol yeller running I have decided to try and get the best mpg out of her I can. im shooting for 15mpg. yeller has a 350 4spd and 1 ton running gear. I believe her to have either 3.73 or 4.11 gears but im not positive. She does about 50mph at 2k rpm in 4th with the sm 465 in her. She is all stock except for a 625 carter afb. I intend to switch to a Q-jet soon. The burb is stock height and runs on 245 75 16's. what can I do to get close to my 15 mpg goal? My neighbor mentioned switching over to a new venture 5 speed from an 80"s model 4x4 which sound ok to me. what can I do here? Im currently getting like 7 mpg and its just not acceptable. it is a 4x4 too.
jims72 is offline   Reply With Quote
Old 08-15-2013, 10:10 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 79 4spd burb milage
The NV4500 will give you an extra gear to help get it moving and the overdrive will help some w/hwy mpg but it won't work magic, that's still a beast. I'd consider a cam that maximizes low rpm torque, get it in the best tune possible, rebuild and align the front end, and run the max tire pressure you can without wearing the centers out. At that point it'll be about as good as it's going to get.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
