Parking brake cable question?
OK....so I took the advice from last night and removed the strut and strut spring from each drum. BINGO the shoes move closer together and BAM the drum slides right on!
So.....I get under the truck and look up at the cable. The cable is sheathed in a flexible sort of tubing at the back and at the front, exposed over most of the middle, and has a connection of sorts very close to the rear coil springs. How can I find out where the trouble is so I can replace this mug? Diagram put up by a helpful member: ![]() *A local garage wants $65.00 to replace each cable even when I supply the parts! Last edited by In The Ten Ring; 08-15-2013 at 06:33 PM. |
Cluster King
![]() Join Date: Nov 2012
Re: Parking brake cable question?
If you look at the diagram from the LMC catalog, you will see item number 5. It does not say what number the other side is but you need #5 for the left and #? for the right. That is usually the piece that is froze up because the cable runs though the inside of the sheathing. One end of that goes through the backing plate and hooks to the parking brake linkage inside the brake drum. The other side hooks to a connector.
If you look at item #12 that is where the adjustment is made. You will need to back the adjustment off all the way and then remove the cables from the connector on both left and right side. getting the other end out of the backing plate is the tricky part. You will have to squeeze the tabs in. The best way I have found to do that is to take a boxed end wrench and slide it over the end of the cable and the wrench will push all three tabs in at the same time. Then you can just pull the old cables out. I would bet this is where you need to start and is the most common problem with park brake cables. I know if you are a novice that this may seem a little confusing but hang in there, you have plenty of help here to get you through this. |
Thanks man and the last words, those of encouragement, went a long way with me.
OK....next question. I'm not a huge fan of LMC....is there a better supplier to get this stuff from? *Now if LMC will work for these parts, then I'm game. |
try a small hose clamp on those brake cable tabs. the wrench sounds good also.
on the cables i have pulled them out and threw them in my oil drain bucket overnite. submerge them an let'm soak for awhile then pull them out an hang'm above the bucket too drip off. when there done drippin wipe'm down and clamp the solid part(the collar on the sheathing) in a vise an keep pulling back an forth till they are free. this could be hard or it can be easy depending on how bad they are. its allways worked for me even though i had some on a 77 that were a bear too get loose. i had too hook a slide hammer too it an really yank back an forth on the cable. of course this is only if the cable isnt frayed or damaged and your workin on the cheap i have gotten new ones from rock auto at a decent price an they fit great fyi.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#5 | |
Cluster King
It may be worth a couple hours of your time to see if you can free up the ones you have but again like midniteblues stated, if they are frayed, they are junk. Good Luck. |
If they have them, Rock Auto will likely be the best source.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#7 | |
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
