Old 08-15-2013, 07:18 PM   #1
1986brownjl
fuel pump question
ok im putting a electric fuel pump for carbs on my 86 k10 that has two gas tanks and wondering whats a good way of wiring it up and what line to splice into to use? thanks for the replies.
1986brownjl is offline   Reply With Quote
Old 08-16-2013, 10:08 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: fuel pump question
In tank fuel pumps out of an 87 would be ideal If you are using a frame rail pump, then you should use relays and power from the battery. Use fuses too. Is the switch valve stock?
Single pump wiring: http://www.jegs.com/i/JEGS-Performan...rentProductId=
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-16-2013, 10:54 AM   #3
1986brownjl
Yea its stock.
