08-15-2013, 08:06 PM | #1 |
fuel filler
I'm trying to find a fuel filler i can mount in my bed floor that uses a 1-3/4 hose and has a 5/8 vent line any ideas/
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-15-2013, 09:47 PM | #2 |
meowMEOWmeowMEOW
Re: fuel filler
You can use exhaust tubing to reduce or splice rubber filler hoses together, essentially as a reducer. You can also just run the vent to a breather or pcv style check ball.
08-15-2013, 10:06 PM | #3 |
Re: fuel filler
Okay so a question on the beather i guess it needs to be higher the the fuel fill or it would over flow when you fill up right?
08-16-2013, 12:54 AM | #4 |
meowMEOWmeowMEOW
Re: fuel filler
I use a vented cap, so it makes itself the high point in the system more or less. The vent on my old tank was just an AN bung in the top to a piece of fuel hose and a keychain sized PCV filter, the ones that look like mini K&N's. As long as the fuel vapor has a place to go, your fine, just try not to vent it straight into a hot exhaust crossover or something.
This is a picture of a modified setup that a guy with a desert-runner truck made. Its a fuel cell with reducers to the factory Ford filler neck and cap, and he's running a breather as well as the factory charcoal cannistor.
08-16-2013, 10:21 PM | #5 |
Re: fuel filler
this.....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-16-2013, 10:28 PM | #6 |
Re: fuel filler
do you have a part number or link for that?
08-16-2013, 10:50 PM | #7 |
Re: fuel filler
ridetech clear anodized #81000034
black anodized #81000036
08-16-2013, 10:57 PM | #8 |
Re: fuel filler
Wow 200 dollars umm wasnt expecting that
08-17-2013, 08:55 AM | #9 |
Re: fuel filler
lol....yeah I should of warned you...
08-17-2013, 06:39 PM | #10 |
Re: fuel filler
I put one of the ride tech ones on my nova it fit great and is a quality piece. I held off for a while because of the price. I think you can get a less expensive version at a boat supply place the have used them for years is kinda new to cars and trucks.
Posted via Mobile Device |
08-17-2013, 06:58 PM | #11 |
Re: fuel filler
I use Marine filler necks all the time, Just fill it slow, They are 1 1/2".....1 3/4" hose will clamp down.
http://www.ebay.com/itm/Stainless-St...a25ae8&vxp=mtr |
08-17-2013, 07:07 PM | #12 |
Re: fuel filler
Sweet kk now i need to figure out what i want to do for the vent was told a normal breather was fine but i am worried about fuel dumping out of it
08-17-2013, 07:14 PM | #13 |
Re: fuel filler
Would this work if i was afraid of fuel spilling out of the vent http://www.iboats.com/Attwood-Fuel-V.../view_id.37945
08-17-2013, 07:28 PM | #14 |
Re: fuel filler
Mount the vent/breather as high above the tank as possible. Behind a rear tail light maybe??
08-17-2013, 07:31 PM | #15 |
Re: fuel filler
Yea i guess tbat would make sense
08-17-2013, 10:42 PM | #16 |
meowMEOWmeowMEOW
Re: fuel filler
The easiest thing I could think of before I changed was just some fuel hose and a breather, zip tied up to the bed cross support.
