Old 08-15-2013, 10:41 PM   #1
eray92
eray92's Avatar
anyone running an overdrive trans and 4.56s?
I just swapped in a 200-4r trans into my truck and a gear locker but kept the 3.08s. I have drove it about 160 miles since the swap. the 383 has enough torque to pull it in 4th gear with torque converter locked but its at 1300-1400rpms. the truck is driven mostly city miles. I live 5 miles from my work and about 10 miles from the grocery store. it will never get on the interstate. I have some 4.56s from my old truck and thought about throwing them in. I have 255/45/20s on there which equals a 29.4" tire. rpms at 60 would be around 2100. that's better than running a th350 and 3.08s.
what are your opinions and personal experience?
eray92 is offline   Reply With Quote
Old 08-15-2013, 11:47 PM   #2
Ziegelsteinfaust
Re: anyone running an overdrive trans and 4.56s?
I did with an 07 GMC with the 4.8, and it worked great for my truck.
My concern with yours it that it will be a burn out machine, but your city mileage would be very good.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-16-2013, 02:07 PM   #3
Levi L
I have a 91 CCSWR4X4 with a 350 and the 4l80e /4.56. Tire size 235/85R16.
The best way I can describe it; it likes going 57 mph. It will do 65.. but it doesnt like to.
It seems that the sweet spot is right at 57.
You would be happier tradeing the 4.56 with an off road guy for some 4.11's
Levi L is offline   Reply With Quote
Old 08-16-2013, 03:06 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
I put a set in a 99 3/4 ton once. It had a stock 350, pulled like crazy with those gears.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
