![]() Join Date: Aug 2013
Here I go again needing help (dash cluster)
I still haven't picked the truck up yet and will post pics as soon as I get it on Sunday or Monday.
I have found a dash cluster with a tach and a vacuum gauge. Again, being the non-mechanic, will the tach and vacuum gauge work on my truck? Will I need anything other than the replacement dash cluster? I keep finding things I want to buy for the truck. |
Re: Here I go again needing help (dash cluster)
And the truck is???
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
Moderator
![]() Join Date: May 2007
The tachometer uses a separate wiring harness. They are readily available from many vendors. The vac. Gauge is mechanical and will need to be plumbed to a source on the intake manifold via a hard line, as a rubber line will collapse under vacuum.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Truck is a 1971 Chevy C10 SWB
Thanks for all the info |
#5 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thank you for the info
