Old 08-16-2013, 12:50 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
removing bed
i want to remove my bed so i can re-do my wood and retighten bolts.its a fleetside,never done it.is it easy to do?can i do this by myself?any pointers,or tricks,all suggestions will be appreciated.thanks brforehand
1966FLEETSIDE is offline   Reply With Quote
Old 08-16-2013, 02:09 AM   #2
donthekawguy
donthekawguy's Avatar
Re: removing bed
I took mine off by myself. Most of the wood was already out and it had been off before so the bolts came out easy. Once I had the bolts out that hold the bed down I hooked up ratchet straps to my engine hoist and lifted it off. I just pulled the truck out from under the bed and set the bed down. Then I tipped it up onto a piece of plywood so I could get at the rest of the rusted bolts.
The straps are on there now to hold the bed up when it gets windy.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-16-2013, 09:22 AM   #3
1963c-10
1963c-10's Avatar
Re: removing bed
Looks like an old triumph behind the bed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
