41 chevy panel truck
would this be the right forum to find out more on a 41 panel truck? I'm picking one up tomorrow morning weather permitting. thanks
Re: 41 chevy panel truck
I believe your in the right place
![]() Post pics when you get them. |
Mostly curious what people are doing to swap in a newer drive train. Motor mounts, which motor Trans combo fits best etc. not sure I know how to post pics
Posted via Mobile Device |
You can do pretty much whatever you want to do from straight 6 to big block Chevy. Check out the projects and builds section to get an idea of what you can do.
http://67-72chevytrucks.com/vboard/s...d.php?t=551088 http://67-72chevytrucks.com/vboard/s...d.php?t=491077 http://67-72chevytrucks.com/vboard/s...d.php?t=558819 |
What rear end swaps out easily? What years are similar? What do they have in common with pick UPS?
What drivetrain do you want to use? What front suspension are you planning to use?
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
I have a low milage (70k) 5.0 chevy truck motor I'd like to use. I also can pick up a 10 bolt Nova rear for near nothing. Front suspension... May be stock for now
All of that should work. I think the Nova was a coil spring rear end so you may have to grind off the mounts and weld on leaf perches. Pinion angle is key to success...do some research on it. Measure the width of the rear end for comparison and make sure it will work with the clearance in the wheel wells. You will end up with a five lug rear and six lug front.
The Nova is Leaf spring not coil. But I'm assuming the perch width will be diff and need new ones anyway. it's roughly 1/2" narrower than the oem rear. Diff wheels would be in the future anyways(not crazy about the ones on there and would like to go more 40's style so new wheels can be any bolt patter) What is the same on these as the pick ups? what is an easy way to change the front end to add disk and more modern suspension? Thanks
| Bookmarks |
