Gauges for 63 gmc
I need to replace mine i will only be replacing the gauges as i cant afford to upgrade to a new cluster, can someone give me links to some or let me know of what you have used.
![]() Join Date: Oct 2006
Re: Gauges for 63 gmc
I used some aftermarket gauges and speedo when I did mine. Keep in mind that our fuel gauge is a 30ohm and not the common 90 ohm.
The speedo and fuel gauge are auto meter and I used an inexpensive tripple gauge set from Autozone for the volt, oil and temp . I used some small green lights forr the turn signals and a red light for the high beam indicator. Its an easy project .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
any specific brand or just anything that is the same size? im going to start working on it this weekend i hope i can finish it.
#4 | |
2" gauges. I used my original cluster to make a patern on masonite board Drilled out the hoels and covered it with some chrome sign tape. It was ony to be a temp fix but its been on for a while. I can take some photos for you if you like.
here I what I did on my 60 Chevy:
It came out nice, thanks for the info as this is my first build and i just rather ask as many questions now then to do it all wrong.
Posted via Mobile Device |
