Old 08-16-2013, 02:23 PM   #1
WhippinSaw
WhippinSaw's Avatar
sagging front coil spring
I have a 63 c10 with a 327 powerglide and have to replace my front coil springs again. I put the set in from classic parts but one of them sagged noticeably and the alignment shop said I had to replace the defective spring before they could align. (I got store credit back from them) I need to order another set but want to check here before i do another install. Does anyone have a part number or know what springs I should get.
WhippinSaw is offline   Reply With Quote
Old 08-17-2013, 03:15 AM   #2
jtrichard
Re: sagging front coil spring
here is a moog number http://www.jegs.com/i/Moog/719/6082/10002/-1? $75 each ...moog has been good stuff in the past
jtrichard is offline   Reply With Quote
Old 08-17-2013, 06:53 AM   #3
Sharps40
Hear is the front springs, $116 a pair, Advance Auto, Good Moog brand, its what I have on John Lee
http://shop.advanceautoparts.com/web...chTerm=springs
Here is the rear springs, $126 a pair, Advance Auto, again, good Moog quality and these are variable rate rear springs.
Now, Anything over $100 ships free. And, use code P20 and you get an additional 20% off (maximum of $50) so yer springs come to you and come to you cheeper than over the counter.
Sharps40 is offline   Reply With Quote
Old 08-17-2013, 10:02 PM   #4
WhippinSaw
WhippinSaw's Avatar
Thanks for the confirmation and the deals on the springs. (Moog 6082) At least they will be better springs and cheaper the second time around. I don't think the sagging spring I installed are moog. Cheers
