73 c30 on 36X15.5X20...possible?
So is it possible to mount those tires on a 2 wheel drive truck with out cutting away half the fender? They would be mounted on the 1st attack single steel wheels. If not possible then what modifications would I have to do to make fit?
Re: 73 c30 on 36X15.5X20...possible?
lets see a picture of what you got....
I will post pictures either later today or tomorrow.
Posted via Mobile Device |
[IMG]<a href="http://s1313.photobucket.com/user/stersam1/media/20130816_164438_zps361a8f63.jpg.html" target="_blank"><img src="http://i1313.photobucket.com/albums/t547/stersam1/20130816_164438_zps361a8f63.jpg" border="0" alt=" photo 20130816_164438_zps361a8f63.jpg"/></a>[/IMG] I should have said that it isnt a 1 ton yet but a 3/4 ton...
Hmm why isn't my picture showing up..
36 by 15.5 by 20?!?!?!?!?!??!?!!?
One of those tires looks to cost more than that whole truck is worth, I'm not Suzie Orman, but i don't think this is a sound financial decision. And you's gonna have tuh re-engineer the whole front suspension and rear suspension a that truck to make them tars fit. Good luck wit at.
I don't think you can run dually rims on a none dually truck.To fit tires that tall you need to lift the truck,The rear would be easy the front you have two options.One is find a fabtech 2wd lift kit used since they stopped making it,Or get the 88-98 lift spindles and do the swap parts thats needed and new 1 ton springs.
Alrighty then...ill see what I can find around here and I'll go from there. Thank you for your opinions
#13 |
I gotta ask why do you want a 20 inch rim?
#14 |
I like the bigger wheel
