![]() Join Date: Jul 2002
Hi there... I need some help knowing which set of heads to use.....I have 2 sets...both magged and good to go....
the 1st set #'s are 14101083 The 2nd set is 14102193 this is going on a factory replacement motor.....just wondering if anyone knew which set was better? Thanks........ ![]() ![]() ![]()
Patch |
.....only info i have is the 14101083 is 87 and up 350 64 cc chambers...and the 14102193 all i have is 87 and up 350..so i'm guessing there pretty much the same heads
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
So it appears that there both 64 cc heads?
Patch |
The one set has round push rod holes...and from what I'm understanding, these need self aligning rockers....the other set of heads have almost a rectangle shaped push rod hole...can these take normal rockers? Thanks again......
Patch |
its all about the +6 inches
being that they are both 87 and up, You'll probably need the vortec intake, self alighning rockers, and centerbolt covers.
#6 | |
Only if they are 96 and up Vortec heads. You will need the center bolt covers though. |
DOH! Thanks, Jason.
