Old 08-16-2013, 05:58 PM   #1
JOJABOY
Brake light switch
I have a question about the brake light switch mounted to the brake pedal assembly. I see the Orange and White wires coming out of the back of it. My question is.....
When the button is depressed, does the switch complete the circuit on the ground side?
If I am correct, does the orange wire go to ground and the white to stop lamps?
I have the wiring diagrams but seem to not be able to follow it with the wires going into the switch assembly.
JOJABOY is offline   Reply With Quote
Old 08-16-2013, 07:11 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Brake light switch
It's a NC switch. The orange wire comes from the fuse and the white wire goes to the turn signal switch.
All power side switched.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-16-2013, 07:16 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Switch is open when brake pedal is not depressed and button is pushed in.
Closed when pedal depressed and button is out.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-16-2013, 07:19 PM   #4
cdowns
cdowns's Avatar
the ground for the stop lights is the case of the light bulb to the socket to socket holder to bed to frame to battery
Old 08-16-2013, 07:23 PM   #5
JOJABOY
Hmmmm..... So it's on the positive side. Was just curious. I am gathering all the parts and pieces for my OD trans and lock up kit. The TCI lock up kit unlocks when accelerating (vacuum switch) and unlocks when down shifting. However, I want it to also unlock as soon as I apply brakes also.
Old 08-16-2013, 07:46 PM   #6
JOJABOY
So when brakes are not depressed....the pedal is up and therefore pushing the button on the brake switch keeping the 12v power from reaching the lights. And when you hit your brakes the pedal goes down releasing the button and therefore applying power to the brake lights. Right???
The following came from the TCI kit instructions:
Option 3 is for those who desire immediate release of the TCC when braking. For
this, you'll need an OEM brake pedal switch with a normally closed circuit. Run
your switched 12-volt source through the brake switch and then to the red wire
on the TCIŽ external harness.
How can I accomplish this?
Old 08-16-2013, 08:14 PM   #7
Bigdav160
Bigdav160's Avatar
I don't know where the red wire on the TCI kit goes.
Two ways I know to accomplish what you want are to install a dual switch. I think the GM N body switch fits and one set of contacts are NO and the other NC. You should be able to find a part number if you search this site.
Otherwise you could use the OE brake switch to trigger a relay that would cut power to the TCC solenoid when the brake pedal is depressed.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 08-16-2013, 08:26 PM   #8
JOJABOY
The red wire is 12v swithed. A dual switch (one NO and the other NC) would work. The idea is the 12v (red) wire applies power to the 4th gear solenoid. It locks the torque converter when in 4th gear.
A vacuum switch allows the power to the 4th gear solenoid when there is 8-10 feet of vacuum. The vacuum switch unlocks the torque converter via solenoid when accelerating (drop in vacuum). The solenoid unlocks the torque converter when the transmission down shifts.
By placing a Normally Closed (NC) switch in line of the 12v power (red wire), it will allow the capability of braking then accelerating. The torque converter will instantly unlock.
Old 08-16-2013, 09:18 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
The brake light switch circuit is closed with the switch released. If you push the button on the switch it opens the circuit and the brake lights go off.
"The idea is the 12v (red) wire applies power to the 4th gear solenoid. It locks the torque converter when in 4th gear."
Maybe I don't fully understand but if the above statement is true, the brake light switch will do the opposite action of what you need. When you push down on the brake you want the solenoid to unlock with power not lock, true?
TBONE1964 is offline   Reply With Quote
Old 08-16-2013, 09:44 PM   #10
JOJABOY
You are tracking correctly. I think I need a switch that does both. One circuit that is open when depressed and one circuit that is closed when the button is depressed.
Name:  brake switch.JPG
The brake lights would run through to Normally Closed side and will get power and light up when brakes pressed (button released).
The red 12v switched wire would run through the Normally Open side and the lock up kit (4th gear solenoid) would have power except when brakes pressed (button released)
