Old 08-16-2013, 11:44 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Bilstein Shock Question
Okay, I'm ready to pull the trigger and order a set of Bilstein Heavy Duty Mono-Tube Gas Shocks for my 72 long box trailing arm stock height truck. Does anyone have a of these on their truck and if so how long have they been on and do you find the ride and handling of the truck any better, harsher etc. ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-17-2013, 12:11 AM   #2
geezer#99
geezer#99's Avatar
Re: Bilstein Shock Question
I just replaced my Bilstein's on my truck with a set of Napa Response shocks. It's an 84 c10. Way nicer shock. Smoother, not bone jarring over bumps. The owner of the Napa said while the bilstein's are a good shock they're intended to keep a high performance wider tire firmly planted on the ground for handling. Truck's don't need that type of shock unless you're building an autocrosser.
With the bilstein's you're buying the hype. Everybody thinks they need them. You need a shock that smoothly absorbs the bumps in a street driven truck.
Old 08-17-2013, 02:42 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
+1! Monroe shorty's on the truck...Bilstein's on the stock car...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 08-17-2013, 07:46 AM   #4
Already Gone
Thanks for the responses, now I'm not sure if Bilstein is the way to go.
Old 08-17-2013, 08:16 AM   #5
nobolt
nobolt's Avatar
that makes sense....may as well save a few dollars and invest it somewhere else in the truck.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 08-17-2013, 10:44 AM   #6
Lee H
Lee H's Avatar
IMHO, Bilsteins are a great shock. Bilsteins will easily get over 100k miles and are warranted for life. If they ever get spongy or leak Bilstein will replace them. The are standard equipment on many GM four wheel drives, all Z71s all S10 four wheel drives and extremes. they are also the OEM supplier for about 30 other GM vehicles, all Mercedes Benz, lots of BMWs, and many other car and truck manufacturers. They do cost more but this is another example of you get what you pay for.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-17-2013, 12:19 PM   #7
Sicklajoie
The Niner
Sicklajoie's Avatar
I can't find the correct Bilsteins for a coil spring rear 69 C/20.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 08-17-2013, 02:49 PM   #8
Lee H
Lee H's Avatar
CCP carries Bilsteins repackaged by RCD, Race Car Dynamics, out of San Diego. I got mine from RCD before they started selling to CCP. Give CCP a call. If hey can't help call RCD, they will get you the correct part and let you know where you can buy them from as I think they are now strictly wholesalers. Be ready with a few answers about the ride height, like the measurements from upper to lower shock mounts, and the measurement from bump stop to where the stop hits at ride height.
Old 08-17-2013, 05:17 PM   #9
Already Gone
I know Bilsteins are a great product, they are are on my dd 99 cop tahoe and work perfect on there. My concern is will the ride quality change on my truck because it rides so well now I dont want the ride to be harsher with the New shocks. I can get a pretty good deal on them at EShocks.com
Old 08-17-2013, 06:25 PM   #10
clinebarger
The Heavy Duty version will be a little rough, Unfortunately they don't make a Comfort or 5100 shock for these trucks.
With a big block, Running the Heavy Duties on the front will be perfect, The rear will beat you up unless its loaded.
clinebarger is offline   Reply With Quote
Old 08-17-2013, 06:40 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I gotta ask, if your truck rides so well now, why are you replacing the shocks? When I buy new shocks, it's because the old ones are worn out (or degraded enough to bother me) and as a result, the vehicle no longer rides well.
Have you considered Monroe Sensatracs? I've heard nothing but good about them, mainly about their ride quality.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-18-2013, 02:03 AM   #12
Already Gone
I thought someone would ask that question. I am changing the rear differential on my truck. I've had the truck since 2001 and haven't changed the shocks. Although the shocks arent leaking the rubbers are all squished and cracked and the shocks have no paint left on them so for all I know they could be originals. My thinking is that if I am going to yank the diff I might as well change out the shocks at the same time, Then as long as I have the truck ( and it will be in my estate) I know what I have.
I first looked at Monroes but they wanted 92.00 a piece here.
Old 08-18-2013, 10:16 AM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Try expanding your search.... I checked just one place, Summit Racing, and they want $37 each. Other places might be cheaper...
http://www.summitracing.com/parts/mo...del/c10-pickup
- Mike -
RIP El Jay
