Old 08-17-2013, 08:09 AM   #1
kgmunro
Front coil overs?
Has anyone seen or used front coil overs instead of springs for a 66 style truck with the 80 style control arms? I see these on everything else but not these type of trucks.....available??
kgmunro is offline   Reply With Quote
Old 08-17-2013, 11:24 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Front coil overs?
PorterBuilt has a c-4 style. No Limit. Ridetech. And few others. If you have 80s stuff already then maybe not.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-17-2013, 05:24 PM   #3
kgmunro
Thats kinda what I meant...to put on the 80s suspension, not a whole different suspension.
Old 08-17-2013, 06:53 PM   #4
LVPhotos
LVPhotos's Avatar
http://www.porterbuiltfabrication.com/?p=453
Must use tubular a-arms for coils. Not changing center section just order arms.
http://www.classicperform.com/NewPro...s/QAShocks.htm
Easy Bolt-In Installation
Minimal modifications to be made. Remove the existing shocks and springs and the QA1 Pro Coil System bolts right back in.
• Specially Designed Conical Springs
This spring is designed so that the lower end sets on the coil-over shock and the upper end sets in the original spring bucket in the frame. This allows for the use of a longer and lighter spring for more stored energy, offering increased weight transfer. Greater durability is also achieved by locating the spring pressure in the frame and not on a single stud.
• Ride Height Adjustable
Threaded aluminum body allows ride height adjustment.
• These shocks are revalveable and rebuildable by QA1 Authorized Service Centers
The QA1 Pro Coil System utilizes the Proma Star® single and double adjustable shocks. The Pro Coil System includes:
• (2) Proma Star® coil-over shocks
• (2) specially designed conical springs. Two progressive spring rates are available, based on small block (250/350 lbs.) or big block (365/465 lbs.)
• All Mounting Hardware
These are not cheap shocks but the Finest Never Is!
• QA1 Pro Coil System Shocks
Old 08-17-2013, 06:59 PM   #5
LVPhotos
LVPhotos's Avatar
http://www.ridetech.com/store/1963-1...rq-series.html
Go Back
View larger image
1963-1972 Chevy C10 - Front CoilOver System - RQ Series
Part #: 11333509
Price: $550.00
Quantity:
Add to wish list
Description
Features
Product News
Share
Testimonials
Required products
Ridetech Coil-Overs
*Requires RideTech StrongArms for proper installation.
RideTech continues to offer today’s hot rodders the ultimate in ride quality, handling performance, technical support, and now, SIMPLICITY, with the new RideTech Coil-Overs.
Anodized finish protects against corrosion
Available as fixed valve or rebound single adjustable
CNC machined billet hardware
Unique pinch clamp height adjuster uses finer thread for easy adjustment
Includes 1/2" bore x 1" kevlar lined bearings for noise free operation
RideTech 2 1/2" coil over springs
built in Indiana by HyperCo:
High tensile premium steel CNC cold wound, less weight, more resistant to bowing, increased travel with durable powered coated finish
Monotube gas pressure design offers superior fade free performance
Impact forged aluminum body provides superior strength and reliable service
Larger 1.834" piston provides outstanding ride quality
Double sealed rod guide with dust cover eliminates oil leakage
5/8" chrome shock shaft
RideTech Aluminum MonoTube Shocks
Great Performance
Mono-tube construction sets this coil-over shock apart - it means consistent performance and great ride quality
Applications
Musclecars
StreetRods
Trucks
Powersports
Categories
Suspension Packages
ShockWaves
Coil-Overs
Q-Series Shocks
StrongArms
MuscleBar
Bolt-On 4-Links
Universal 4-Links
TigerCage
Tru Turn
Control Systems
CoolRide
AIRoverLeaf
TowPro Kits
Components
Accessories
Free Catalog
My account
Sign in / Register
Orders
Wish list
Payment Options
Payment Options
Payment Options
Old 08-17-2013, 07:02 PM   #6
LVPhotos
LVPhotos's Avatar
http://www.ridetech.com/store/1971-1...rm-system.html
1971-1972 Chevy C10 - Front Control Arm System
Part #: 11352699
Price: $1,400.00
Quantity:
Add to wish list
Description
Product News
Share
Instructions
Testimonials
Related Products
What says “performance” more than a set of tubular control arms! After all of the time and effort expended on your ride, you definitely can’t let your stamped oem control arms detract from all that work. Finish your suspension off with these new tubular control arm systems from Ridetech. Built with all of the care and experience you have come to expect from us, these tubular control arms are a precision engineered solution for ShockWave® installation, ball joint binding, and frame clearance issues that can haunt some vehicles. When you combine the performance benefits with the elegant design of these arms, there is no question.... You want these.
Development - StrongArms™ are developed by Ridetech® in Jasper, Indiana on an actual running, driving vehicle. This allows us to properly address ALL fitment and performance issues. It also allows us to document an installation, demonstrate the installation to our sales techs and dealers, and allows ongoing evaluation of the performance of the StrongArms™
Design - We think the best way to design any component is to keep it simple. That is why Strong Arms™ are designed with as few components as possible. We have a new 4 axis tubing bender that allows precise, repeatable bends that no other machine can achieve. We can create elegant tubing bends that would otherwise require several separate welded components.
Components - We have worked closely with Moog, a major manufacturer of OEM ball joints, to ensure that the proper ball joints have been selected for the Application... a compression style unit in a compression application, a tension bal joint in a tension application. Proper bushings are selected based on application and the type of driving or racing that is anticipated.
Geometry - Geometry of a suspension starts with the position of the frame mounts and the height of the spindle, not the shape of the control arm. However, there are a few small things in control arm design that can make a big difference in how a vehicle drives and performs.
We create extra caster potential by adjusting the fore and aft position of the ball joints. At the same time we make sure the wheel is properly positioned in the wheel-well so your new 18" wheels fit like they should!
The balljoint camber travel is re-centered to accommodate the new lowered ride height so the ball joint doesn’t bind during extreme suspension movement.
The perimeter of the StrongArms is contoured to allow maximum wheel clearance and turning radius.
All shock mounts, airspring mounts, and swaybar mounts are integrated into the design so you don’t have to finish the engineering in order to enjoy your ride!
StrongArms™ are optimized to allow proper camber adjustment at your new lowered ride height without using a large stack of shims.
All STRONGARMS include ball joints, and bushings. They are bolt-on: ready to install!
Old 08-18-2013, 12:47 AM   #7
Captainfab
60-66 Nut
Here's a thread on how one member converted to front coilovers.
http://67-72chevytrucks.com/vboard/s...light=coilover
