Old 08-17-2013, 11:00 AM   #1
77 ChevySport
Question Horn question for 1977 Stepside
My horn seems to work about 80% of the time. I believe it is a ground
problem on the horn assembly. My horn is located between the radiator
and grill on the passenger side. My question may possibly be applied to
a great many other Chevy PickUps. Here goes:
What is the most simple and painless way to get to the horn to work on
it. There is very little room from the bottom of the truck to stick your
hand in there. I have jiggled the wire but would like to get in there to clean
the contacts better and clean the ground connection. All help is welcomed and thanks in advance. Larry
P.S. Everything checks out OK on the Steering Horn Buttom
77 ChevySport is offline   Reply With Quote
Old 08-17-2013, 11:43 PM   #2
lap15
Re: Horn question for 1977 Stepside
Unscrew the grill and remove it to get to the horn. Clean the contacts really well and you should be good.
lap15 is offline   Reply With Quote
Old 08-19-2013, 06:47 PM   #3
77 ChevySport
Re: Horn question for 1977 Stepside (ShortBed)
Ok; here is my update: Got the horn working well by cleaning the ground
and the wire (contact) on the horn. Did not have to take the grill out just the
passenger side Bezel. Also this perticular truck has only one horn. Larry
