Old 08-17-2013, 01:19 PM   #1
rossboss
rossboss's Avatar
selectro hub removal help needed
I've got a 65 k10 with selectro hubs I need to remove. Removing the locking portion was easy three set screws and it slid right off. I removed a spiral retaining ring from the inner gear section and thought it would pull right out. It wont budge but see no other type of locking device holding it in. I guess what I need to know is if it's a pressed fit and do I need some kind of hub puller to remove it.
rossboss is offline   Reply With Quote
Old 08-17-2013, 03:19 PM   #2
1963c-10
1963c-10's Avatar
Re: selectro hub removal help needed
GM Service manual shows:
1. Turn hub key to set hub to "free" or disengage" position.
2. Remove outer clutch ring, cap and cam assemblies as follows: remove internal snap ring from hub and pull assembly out of hub.
3. Remove snap ring from end of axle shaft.
4. Pull bushing and inner clutch ring assembly from shaft.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-17-2013, 10:43 PM   #3
rossboss
rossboss's Avatar
Those are directions to remove the stock spicer hubs. I'm trying to remove aftermarket seletro hubs. thanks for trying.
Old 08-19-2013, 08:34 AM   #4
1963c-10
1963c-10's Avatar
No problem. Did you get it sorted out? Might try posting in the 4x4 section
