Door speaker install- how to?
My '73 has cut outs in the doors for 5-1/4" speakers. I just bought a set to install but I can't figure out how to run the wires in to the cab. I don't see a hole in the cab to run it through. Any ideas?
Posted via Mobile Device |
Re: Door speaker install- how to?
Drill one? That's what I did
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
Project Heaven in my 67!!!
Go to the wrecking yard and pull a truck apart that had PW, PL and use the original boot from it. measure the holes and cut it exactly like they are and it will give it a more factory look. Just an idea.
#4 | |
once you get the boots (available aftermarket or oem still), problem is you gotta remove the door to do it right. if you look at the door jamb on the cab AND the door, you might see 3 little indention on both, the middle hole is for the wires while the other 2 (top and bottom) are for rivets or screws to hold the boots to the door/cab it is worth the extra work, in the mean time locate the indention and drill small 1/4 hole, run your wires and put some of that flex wire saver crap you get at the parts house on it, and a rubber grommet to keep from cutting the wires on the newly drilled holes. -Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
78K & 79C Jimmys
not the right way to gain access lol , but that's the boot
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
lol @ motornut
Looks good. Thanks
If i remember right i think Motornut had a little help from a drunk driver.
Those baffles are good for keeping your speaker dry, cut the backs out of em though.
#11 | ||
78K & 79C Jimmys
#12 | |
