No break light one driver side...
I tried to search with not much luck so I will just ask. I have no break light on the driver side. I do have parking lights and turn signal which is what is throwing me. If the turn signal is working I would think the break light would also work since they use the same wire. What do I need to check?
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
Re: No break light one driver side...
Sounds to me like a signal switch in the steering column.
A friend of mine had the same problem.He call me and ask me if I had good used housing.So go over to his house and install the used housing and still no brake light.I ask him if he put a new bulb in, yes he did.So I check power to the housing socket,getting power.So took the light bulb out of passger side and it work.A bad new bulb.He brought a couple of pack of bulb from Advance Auto to change bulbs,he just brought the truck and was getting all the lights to work.The bulb look good,just bad bulb.Keep on trucki''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
![]() Join Date: Nov 2007
Had a similar issue and i agree with mikeshome it was a bad signal switch.
Yeah I think you guys are right. I can mess with the blinker leaver and get the drivers side break light to come on...
![]() Join Date: Dec 2012
My Right turn signal doesn't come on :/ ...How much is one of them Motor things
Could it be a bad Fuse?
1971 GMC Sierra 1959 GMC 100 |
