Is this normal..?
So we pulled off the intake manifold and were greeted by this. Not sure if this is normal or what, but it looked bad to me. This gunk (burnt oil?) is just all over the inside, I'm surprised it even ran like this. What does this indicate? Is this normal?? Thanks in advance.
Active Member
![]() Join Date: Sep 2011
Re: Is this normal..?
I have seen way worse than that! Usually caused by lack off oil changes
#3 | |
I have a radical idea!
That's the lack of oil changes and the crusty oil that had burned off the choke crossover through the intake. Sadly, I've seen much worse as well. I saw a 305 one time that had the shape of the valve cover molded in in crust around the valves. There was only enough room for the rockers arm to move. It was pouring smoke out of both pipes and pouring oil out both valve cover gaskets because the oil could return and it was running past the valve seals. The guy chipped it all out, sucked it out with a shop vac. The engine stopped smoking and he drove the car for quite a while he was building a new engine with no issues.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
This is not normal even though lots of folks have seen worst. This crude gets washed though the oiling system wiping out valve guides, rings, bearings, cranks, and cams.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
That bad on top imagine what the oil pan looks like inside.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
To add on to this.. Could this contribute to bad compression at all?
Cluster King
![]() Join Date: Nov 2012
Yes, as others have mentioned, lack of oil changes is the root cause of this and it is a result of what happens when oil gets old and breaks down. It turns to this crust from heat which is why you don't see it in the oil pan. Not as hot down there. It is abrasive and will cut the engines life in half and I am sure if you did a side by side test with a well maintained engine, this one would lack compression also.
Clean it as good as you can and run it. I would be preparing a replacement engine if it was mine. |
Agreed - It isn't normal - but it is common. A well maintained engine won't do that...
Yeah, I figured that was the work of a previous owner. I was just saying that was the reason it did it. If you clean it up and keep it changed from here on out, it will probably last you a while.
#13 |
Good to know. I plan on running a full rebuild kit, cleaning the hell out of it, replacing anything that needs replacing. So this problem should be like it was never there. Appreciate all the replies.
#14 | |
Cluster King
Just my thoughts |
#15 |
If you do a rebuild use that block.The vertical rectangular casting bars in the intake valley just below the intake ports indicate that you have a nice high nickle content block.A good foundation for a rebuild
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
