Headlight bucket mod
I bought some new 7" headlamps that use the H4 bulb's, come to find out that the bucket opening will need to be opened up about 1/4 inch in all directions to make them fit,
If i decide to go back to sealed beam say if a rock takes out one of them out and i'm in a pinch, will the sealed beam still sit tightly in the bucket? or will the mod make a sealed beam not fight tight? Debating if i should just buy a second pare and modify those instead. Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Headlight bucket mod
ttt
#3 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Ok Thank you!
Just dont get greedy and cut too much off. If you cut too much you lose the nubs on the bucket that allow you to aim the headlight. Then you will have to buy another set of buckets to make them work.
Yep, ask me how I know not to cut to much... |
Thanks Shortfleet, I'll look it over closely
