Old 08-18-2013, 02:35 AM   #1
Darren MagooGardner
TH350 to 700r4 swap
I am wanting to replace my TH350 with a 700r4 in my 72 swb c10. I would like to hear some pros and cons of the swap? any advice wood be helpful.
thanks
Darren MagooGardner is offline   Reply With Quote
Old 08-18-2013, 03:24 AM   #2
JOJABOY
Re: TH350 to 700r4 swap
There are no cons outside of the cost in the swap. What gear ratio is your rearend? Overdrive equals better fuel mileage and happier driver. 700r4 has a wicked 1st gear too. But you are looking at a couple grand in the swap and that is getting a good rebuild trans.
JOJABOY is offline   Reply With Quote
Old 08-18-2013, 09:44 AM   #3
slow-1
slow-1's Avatar
I love mine...been running it for 11 years.
Only con I know of is that you can't scare people when you pass them on the highway with your screaming exhaust...unless you pull it down into third when you go by.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-18-2013, 05:15 PM   #4
Z10
Z10's Avatar
I'm in the middle of this same update. I'm dropping in a new 350 ZZ4 crate motor and a GM certified 700r4 out of a 90 Corvette. There are much cheaper ways to do this, but I want it done and forget about it.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 08-18-2013, 10:17 PM   #5
Darren MagooGardner
my rear gear is a 3.08. Wood it be better with a 3.73?
Old 08-18-2013, 10:19 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The 3.73 and 700R4 is a great combo. Just dont go alot shorter than a 28" tire. Then the RPMs start creeping back up on ya.
--Josh
Old 08-18-2013, 10:23 PM   #7
Darren MagooGardner
I will be running 235/75/15 tires.
Old 08-18-2013, 10:43 PM   #8
ol_skool_chevy
ol_skool_chevy's Avatar
I have 235/75/15 with 7oor4 and 3.72 gears...............I love it. best thing I ever did...and shifts Hard enough to bark in all gears if I stand on it..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
