![]() Join Date: Sep 2011
1970 LWB Frame - Restored
If I'm ever going to get my SWB project done I need get get a few things gone....... $2500
Frame is a VERY clean original from AZ. Frame was cleaned, metal prepped and painted w SEM "Rust Shield" Can be set up for SB 350/350 combo or BB 402/400 combo. Which I have both if interested for extra. Items included: Panhard bar bushings Trailing arm bushings Rear - 3.73 open New Moog var. rate Coil springs new axle seals new outer axle bearings new brake shoes new brake hardware kit new brake e-brake hardware new wheel cylinders new diff cover gasket diff fluid Front - 71/72 Disc new Moog coil springs 71/72 Spindles new calipers new brake pads new soft brake lines new inner bearings new outer bearings new disc seals new rotors new upper ball joints new lower ball joints new upper control arm bushings new lower control arm bushings Steering - 72 Saginaw PS box new inner tie rods new outer tie rods new tie rod sleeves new idler arm new pitman arm Sway bar w new bushings and brackets Bilstien Shocks, Ebarke cables and all lines are now installed...
1967 C10 SWB Owner - Rustbelt Restorations Last edited by DaHos; 09-03-2015 at 07:03 AM. |
| Bookmarks |
