Old 07-04-2003, 10:32 PM   #1
krue
Designated A-hole!
krue's Avatar
Tire size?
What is the height on the original tires for our truck? I need to figure how far off my speedo/odometer is off.
Thanx, Krue
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-04-2003, 11:32 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
For starters, what size came on your truck? Mine came with 7.50-16s, which may be taller than your OEM tires. :p
This chart may help you... http://www.tirerack.com/tires/tirete...k/truksize.htm
You can also clock a measured mile and use this chart http://www.tirerack.com/tires/tirete...o_accuracy.htm to determine your actual speed.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-05-2003, 01:04 AM   #3
Phillip Johnson
Phillip Johnson's Avatar
My first 72 3/4 4x4 Cheyenne came from the factory with 9-50/16.5 bias ply tires. I since changed to 235-85R/16's
Phillip Johnson is offline   Reply With Quote
Old 07-05-2003, 09:27 AM   #4
dwaite72lnghrn
Find a highway that has mile markers. Note the odometer as you pass one, run at least 10 miles(makes it easy) as you pass the 10th mile marker note the odometer( speed does not mater). If the odometer is 9.5 miles you are 5 percent to fast, If it is 11.5 you are 5 percent to slow find the gears for trany that will give you that change. The more mile markers you pass the more accurate it will be.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
