Just found out that my passenger rear shock mount (ON THE FRAME) is broke right where the shock mounts on the stud....
Does anybody know where I can find these to replace them with new ones? I'm gonna just go ahead and replace them both since they are originals from 1984.... Thanx for all the help guys ![]() ![]() ![]() ![]() Posted via Mobile Device
KAOTIK Kustumz 1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW) 1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop) |
#2 | |
Conversion Truck Addicted
Re: 1 ton Dually rear shock mounts.... (QUESTION)
junk yard cut the piece out from a junk yard truck i belive they are the same for any 2WD Square body truck
Thomas Quote:
#3 | |
The half ton has a stud straight on the frame, where the 1 ton dually has a mount that is riveted on the frame where the shock mounts to it and the stud is on the riveted mount NOT the frame.... I'll get a pic of what im taking bout and posted it on here for you guys to see what im talking bout... Posted via Mobile Device
At the body shop.
And on the inside of the rail. Junkyard or GM if its available
" That didnt make it any newer " " Dont antique the equipment " |
Here's the half ton truck shock mount....
![]() Here's the dually mount.... ![]() Posted via Mobile Device
had the shock stud on my k30 crew snap. the shocks i bought came with the stud. had to grind out the rivets to get mount off & grind out the old stud. yours looks like if you cut it, it'll fall out. new stud bolts in, new gr 8's on the mounts
