Old 08-18-2013, 08:07 PM   #1
NC_John
NC_John's Avatar
Heater Box Question - am I missing seals?
I tore apart my entire heater system inside and outside the cab. It was completely jacked up with leaves. In fact, a previous operator was trying so hard to open one of the levers that they broke it (so I have to rebuild the heater controls). The damper door they were trying to open/close was packed solid with stuff. I took the entire assembly apart, cleaned and serviced it so it should work like a champ.
Anyway... Please take a look at your heater boxes- is there a gasket or seal missing on my heater coils? Seems to me there should be something there to keep more air in the cab. I can't tell from the parts vendors I checked out if there is supposed to be something there and the service manual doesn't have enough detail...
Thanks!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-18-2013, 08:54 PM   #2
71 super
71 super's Avatar
Re: Heater Box Question - am I missing seals?
Yes there are foam seals that support the tubes
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-18-2013, 08:55 PM   #3
71 super
71 super's Avatar
Kits are available from modern Chevy , Dave's truck parts and all the board venders, gave first two cause they are close to us
Old 08-18-2013, 08:59 PM   #4
NC_John
NC_John's Avatar
Please tell me I do not have to take it apart to install them......
Thanks!
1970 C-10 LWB "Blu"
Old 08-21-2013, 06:57 PM   #5
NC_John
NC_John's Avatar
I went to Classic Muscle today (Modern Chevy) and got some stuff. I was disappointed that a lot of the parts I was excited to see in their catalog were discontinued and no longer available. They didn't have the foam seals for the heater core but did have them within a complete heater seal set that was $19 (I got it).
I also got a set of window seals (felts, channels, etc.) for the doors. That should tighten up the windows and make it sound better when I close a door.
Dave's is way on the other end so I'll have to make a trip out there on a Saturday when I've not got anything else to do.
1970 C-10 LWB "Blu"
Old 08-21-2013, 07:27 PM   #6
71 super
71 super's Avatar
People at modern are always good to me, I like it because I get it next day, I am other side of Asheville. Dave has a lot of stuff and worth a ride to hickory for the tour. Tommy's in Shelby is good too. He worked at modern or flow and retired from there. He knows his gm parts..
Old 08-21-2013, 10:05 PM   #7
NC_John
NC_John's Avatar
Isn't Dave's in Claremont?
1970 C-10 LWB "Blu"
Old 08-22-2013, 08:51 AM   #8
Steve Cole
Hey John, I noticed you live in Rockwell. I live in Faith so if you ever need a hand with anything on your truck, let me know. It would be a shame if we live this close together and don't take advantage of that.
Steve Cole is offline   Reply With Quote
Old 08-22-2013, 09:02 AM   #9
NC_John
NC_John's Avatar
Cool Steve.... PM sent.
1970 C-10 LWB "Blu"
Old 08-22-2013, 09:16 AM   #10
beetle1960
beetle1960's Avatar
They are nothing more than 1/4" foam disks. You could make them and probably get them in there without tearing apart the box. Another possible option, you could use that expandable foam stuff, squirt around the core pipes, let it cure, then shave it off flush with the heater box...then paint it black.
beetle1960 is offline   Reply With Quote
Old 08-22-2013, 07:24 PM   #11
NC_John
NC_John's Avatar
That's a good idea. I bought that seal kit though and took it all back apart today. Broke my heater core in the process and had to have it solder repaired - doh! I'll put it all back together with new seals/gaskets inside and out tomorrow.
1970 C-10 LWB "Blu"
Old 08-22-2013, 07:37 PM   #12
71K20chevy
71K20chevy's Avatar
Is it the original heater core? If so, just spend the 30 bucks and replace it now, because it's horrible trying to replace them. Just my 2 cents
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-22-2013, 08:23 PM   #13
71 super
71 super's Avatar
Dave's is in Claremont
Old 08-22-2013, 08:53 PM   #14
NC_John
NC_John's Avatar
Nope, it's not the original. It's actually in excellent shape (repair guy said so too). I had clamped one of the hoses to the core when I was flushing everything and forgot it wasn't loose when I pulled the hoses off. I pulled the hose off and it took the pipe with it. I had to get it resoldered on.
1970 C-10 LWB "Blu"
Old 08-22-2013, 08:54 PM   #15
NC_John
NC_John's Avatar
My bad, i thought Claremont was down on the other side of Charlotte....
1970 C-10 LWB "Blu"
