Old 08-18-2013, 10:44 PM   #1
jks67ss396
lazy temp gauge
Guys
I have a 71 with temp gauge (not sure if some just came with lights, but i have the gauge)
Anyway, i seem to have a lazy temp gauge. meaning that it just starts moving when the temp is 180 ish.
This gauge always kinda did this and i thought maybe temp sensor. Well, i just completed my 5.3 4l60 swap and i have a temp sensor in the head from a 98 Camaro (works with the pcm and has a port for a gauge). So watching hptuners, I can calibrate the temp in the pcm with the temp on the gauge.
I did ground the sensor wire and the gauge did peg full hot. So i believe the wiring is correct.
Maybe the 5.3 doesnt flow coolant till the tstat opens?
So do any of you other guys have a gauge that always reads low?
thanks!
jks67ss396 is offline   Reply With Quote
Old 08-19-2013, 01:32 AM   #2
wreckedchevy
wreckedchevy's Avatar
Re: lazy temp gauge
mine's in the top of the thermostat housing so no temp until the stat opens up. does the same thing kinda slowly moves off of cold a little ways then hangs there until the stat opens up.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 08-19-2013, 09:53 AM   #3
Lee H
Lee H's Avatar
Re: lazy temp gauge
At normal operating temp my gauge reads just off the cold line.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
