Aftermarket A/C with an ls swap.
I'm sure all of the aftermarket kits will work with an ls swap, but are there any that come with a compressor and mouting brackets for the ls setup? I have my compressor from the pullout, but my motor mounts get in the way and I didn't do the mod to the plates to get them to fit when I put the engine in so I think that is out of the question now. So, does anyone know if any brand offers what I'm needing or if I need to buy the sanden compressor and top mount from one of the available companies, plus the full kit?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Aftermarket A/C with an ls swap.
You may need a high mount AC mount, Kwik Performance and some others off them, With KwikPerformance you would need a Sanden compressor with the appropriate drive. If your going to order from an ac vendor, then just ask for the serpentine belt pulley.
I have seen some with the ability to use an A4 compressor in the high mount config but I am not sure what brand of mounts they are. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks for the info, I was hoping someone would offer the whole kit with the ls mounts but I guess I can piece it together.
Posted via Mobile Device |
Check out Old Air Products. That's who I used and they offer the entire setup
for ls high mount compressor. |
GM ONLY BABY!!!
I bought the Dirty Dingo bracket and then a Sanden comp off Ebay. Just had to purchase a new belt to run everything.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
