Old 08-19-2013, 08:48 AM   #1
pearlsnaps
pearlsnaps's Avatar
1964 C10 Engine Suffix - INFO NEEDED
I bought a 1964 C10 custom over the weekend. The engine looks like it has never been out of the truck.
It is a V8 and has this on the front engine pad. F05IIM
Can anyone help with telling me what it is? I can't get to the back of the motor to get the casting number.
Zach
Zach Carter
Frisco, TX
1969 C10 - Patina
pearlsnaps is offline   Reply With Quote
Old 08-19-2013, 09:01 AM   #2
geezer#99
geezer#99's Avatar
Re: 1964 C10 Engine Suffix - INFO NEEDED
Look here. 1958 283 built on may 11th in Flint.
You'll need the casting number. Use a mirror if it's hard to see.
geezer#99 is online now   Reply With Quote
Old 08-19-2013, 09:01 AM   #3
Sharps40
Per the chart in the LMC catalog, a 64 V8 would be a 283 and the only engine id codes used on the 283 in 1964 were M, MA, MX, MY.
Looks like you don't have an original V8
The F is for Flint MI.
IM was used on 1969 350 Chevy/powerglide taxi. Not sure where IIM comes from.
Sharps40 is offline   Reply With Quote
Old 08-19-2013, 09:10 AM   #4
pearlsnaps
pearlsnaps's Avatar
Thanks for the info. I will see if I can get the casting number later.
Zach Carter
Frisco, TX
1969 C10 - Patina
Old 08-19-2013, 09:18 AM   #5
Sharps40
Check also for a date/clock marking on the block. I think the V8 have them on there just like the I6s. Should give you the month/year the block was cast.
Old 08-19-2013, 11:17 AM   #6
1963c-10
1963c-10's Avatar
I think you mean F0511M, not F05IIM. Its a Flint block made in May 11 with the engine suffix "M" which was a 64 283 v8. So it is probably the correct engine for your truck. You will need the casting #. As F0511M is the engine code stamping #.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-19-2013, 11:22 AM   #7
1963c-10
1963c-10's Avatar
The engine suffix is usually 2-3 letters and sometimes a number.
Old 08-19-2013, 11:57 AM   #8
Sharps40
Makes a lot more sense than a 69 350 taxi motor. I was wonderin what happened to the day/month code and 11 makes much more sense than II.
M would be the correct suffix for 1964.
I think I'm corrected!
Old 08-19-2013, 08:26 PM   #9
LT1 Burb
LT1 Burb's Avatar
What color is it?
LT1 Burb is offline   Reply With Quote
