Old 08-19-2013, 10:15 AM   #1
Oxmarqt
Oxmarqt's Avatar
Visor keeps falling(rotating)
Hey all, quick question I'm sure someone knows the answer to.
My passenger visor keeps rotating down as I drive. I push it back up and withing a mile it is back down. Just halfway down but it is annoying me. Is there any adjustment on this I can make.
Paul
1969 Chevrolet C10 Custom
Oxmarqt is offline   Reply With Quote
Old 08-19-2013, 10:26 AM   #2
msgdsrf
Re: Visor keeps falling(rotating)
lower the drivers to match.
msgdsrf is offline   Reply With Quote
Old 08-19-2013, 11:43 AM   #3
Daner
Daner's Avatar
You have a passenger side visor? Lucky!
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 08-19-2013, 11:53 AM   #4
cmcclean
can you swap visors (sides)? maybe with it facing the opposite direction you will be in a good area for it to hold.
cmcclean is offline   Reply With Quote
Old 08-19-2013, 12:14 PM   #5
cdowns
cdowns's Avatar
i've always solved by takin a visegrip and squishing so it dont slip
Old 08-19-2013, 05:03 PM   #6
sterk44
sterk44's Avatar
Here's the PO's solution to that problem... its functional at least.
I'm subscribed in hopes that someone knows a more permanent (and proper) fix.
Drew
1970 C10 LWB Daily Driver
1971 Nova
sterk44 is offline   Reply With Quote
Old 08-19-2013, 05:23 PM   #7
cmcclean
I was serious with my suggestion. If you swap sides effectively the visor will sit 180 deg. from where it currently is. Maybe there will still be enough drag in that position. Of course I've never pulled the visors off so the mounting may be different but as a quick look I think they are the same.
Old 08-20-2013, 06:13 PM   #8
Oxmarqt
Oxmarqt's Avatar
I am going to give this a try and will report back..
1969 Cheverolet C10 Custom
Monza Red
350/700r4/3.73
28" tires
Old 08-20-2013, 07:53 PM   #9
Sammy
I know you can be more creative than a stringed loop fix. Remove the screws and investigate. At worst end get some loop n velcro at the hardware and stick it to the roof.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-20-2013, 08:01 PM   #10
JCD
JCD's Avatar
Had the same problem on my Barracuda.
Never had this problem on a truck ..yet..and I'm not sure you can take the shaft out of the visor.. but don't know why you wouldn't be able to.
My solution was to take the visor off the shaft, and rough it up with 80 grit paper.. just gave it something less smooth to grip.
Don't twist the shaft in the sandpaper, but draw it out of the paper straight.. like a knife out of a sheath.. this will give you lines along the shaft that will help it grab in the visor.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 08-20-2013, 10:56 PM   #11
Mustard72
Mustard72's Avatar
You can put an ever so slight bend in the shaft, too. That will cause it to bind a bit in the visor, plus you don't have to remove the visor. Just don't overdue it or it will drive you nuts that the visor is bent....
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 08-21-2013, 09:55 AM   #12
mgkgmc
mgkgmc's Avatar
You can work the visor off the shaft with a little elbow grease I have done it several times and maybe you can slightly crimp the metal in the visor where the shaft goes in or try putting a little locktight on the shaft too.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 08-28-2013, 07:24 AM   #13
Oxmarqt
Oxmarqt's Avatar
To wrap this up....
I removed the passenger visor to swap it with the driver side. When I had it out I remembered an earlier post and pulled the rod out of the visor. Inside there is a metal sleeve that I was able to "crimp" tighter. *** be sure to tape up the jaws of your pliers so it doesn't leave marks ***
Result is a visor that stays where it should. Thanks for the insight on this aggravating issue.
Monza Red
350/700r4/3.73
28" tires
Old 08-28-2013, 03:17 PM   #14
cmcclean
Glad you found a solution.
Old 08-28-2013, 10:10 PM   #15
Fitz
Every carpet shop has a sewing machine for binding carpets. They can re-sew your visor to tighten it up on the spindle. You just have to learn how to beg the seamstress..
Fitz is offline   Reply With Quote
Old 08-29-2013, 10:30 AM   #16
mgkgmc
mgkgmc's Avatar
Glad it worked also! It's definitely a annoying had to deal with a few my self.
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
