View Poll Results: Should I put a B&M Truck Mega shifter in? | |||
Go for it | 14 | 34.15% | |
Keep it on the column!! | 27 | 65.85% | |
Voters: 41. You may not vote on this poll |
08-19-2013, 07:19 PM | #1 |
B&M Mega shifter? YES? NO?
Im currently building my 69 swb hot rod and have a column auto shift. I want to buy a new steering that is tilt. The question is should I buy one without the column shift and put a B&M Mega Truck shifter on the floor, or keep it on the column? I already have the truck shifter. This truck is a hotrod and not a show truck. It has a bench seat for now, but I plan on swapping to some buckets at some point. Opinions wanted! Thanks!!
08-19-2013, 07:22 PM | #2 |
Re: B&M Mega shifter? YES? NO?
Unless your truck is pro street style, get a Lokar floor shifter. Way way nicer, suits the truck better.
Posted via Mobile Device Posted via Mobile Device
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
08-19-2013, 07:27 PM | #3 |
X2.
I had a Mega shifter. Hated it! Had to go past reverse to get to nuetral. Motor usually quit as soon as it kicked into reverse. Get a better one like a Lokar. |
08-19-2013, 07:40 PM | #4 |
from what i've seen over the years B&M stuff starts to rapidly go to crap and lookin quite ugly in short order
08-19-2013, 07:44 PM | #5 | |
Anyway, I had one in my truck for a few years and LOVED IT!! You mix horsepower/Posi-traction/and a ratchet shifter together and you come up with alot of fun! But ultimately, its your truck. Do whatever you want.
1970 SWB Build |
08-19-2013, 07:51 PM | #6 |
PROJECT 7DEUCE
I love my lokar shifter...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-19-2013, 08:01 PM | #7 |
I had a couple in some of the v-8 S trucks I built, I really liked them in the S trucks I am not so sure about how I would feel in a C10 that sets up so much taller. Of course I am a LOT older now and would prefer the colum shifter, I think it will look better, but the ratchet is fun to play with for banging gears once it is adjusted.
08-19-2013, 08:18 PM | #8 |
Megashifter doesn't fit the trucks style. It seems like it seriously dominates the interior, overshadowing other features. Personally I think its ugly as well. Lokar and gennie shifters fit the trucks style much better, aiding the character rather than dominating it.
Posted via Mobile Device |
08-19-2013, 08:38 PM | #9 |
Ultimately its a hot rod. The motor I'm almost done building is a nasty 496. It will be backed by a 400 turbo with an overdrive kit. Its a toy and I drive it like one. I just don't know if I will like the way the ratchet shifter will look once installed. I also can't decide on what to do with the interior. I wan the clean look of a smooth fire wall. I don't think I'm going to put the heater core and box as well as the heater control panel back in the truck. I think I'm going to smooth it all off. Suggestions on that are welcome as well! Thanks so far guys!
08-19-2013, 08:41 PM | #10 | |
08-19-2013, 08:43 PM | #11 |
I've had two other mega truck shifters and they were nice and easy to use in the mud trucks anyways.. Geezer, did you have a quick silver shifter or a mega shifter? I had a quick silver that was kind of a pain in the but to use. It had the same problems you described.
08-19-2013, 09:07 PM | #12 |
Had one in mine and it was just too low, I use a unimatic now from b@m and its a lot nicer
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
08-19-2013, 09:16 PM | #13 | |
I suppose it might have worked good in a milder cammed motor. |
08-19-2013, 11:30 PM | #14 |
Hurst quarter stick would be a better choice than the mega shifter.
08-20-2013, 12:14 AM | #15 |
Kill Bill...et
I've got a mega shifter in mine and, aesthetically, I'm not a fan. I don't like the cheap plastic base, the gaudy chrome, and the "t" handle is mullet inspiring. However, my truck isn't fast, and I rarely use the rachet shifter except to keep me frim riding the brakes going down long hills. Now a 16" Lokar shifter.....sign me up!
08-20-2013, 12:57 AM | #16 |
I have had a Megashifter in mine for about 20 years. It has been great, no complaints. suited the truck, I thought, when it was turning to more of a hot rod. But with raising it back up, it looks like a farm truck again. Thinking about taking it out, but wasn't sure what to replace it with. The Lokar shifter sounds great. Would definitely match the current look.
08-20-2013, 05:10 AM | #17 |
Keep a column shift.... Mega shifter looks a bit retro IMO and will date the interior, if you do go for floor mounted go with a lokar..... But stick with the column shift..
08-20-2013, 05:20 AM | #18 |
I have a B&M Quicksilver in my 1/4 ton Thames panel with a blown SBC and love it!
08-20-2013, 08:00 AM | #19 |
I had a mega shifter in my jeep. It does the job, but they just look like crap in my opinion.
Im looking at doing a swap from standard to automatic and will either go with Lokar (which is what everyone seems to recommend) or B&M unimatic (and just change out the t handle).
71 swb 350/4sp manual 5/7 static drop |
08-20-2013, 08:12 AM | #20 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-20-2013, 09:55 AM | #21 |
Stick with the column or maybe go with Lokar. I agree with what many others have said, the Megashifter goes to crud in a quick hurry, it looks cheap, dated, etc. It just doesn't fit these trucks. I just took one out of a project I'm working on, because it looked so bad. It toasted the tranny too, because it got out of synch a little and the PO didn't know it. I personally love the column shifter. It looks better in my opinion, and is out of the way. Unless your racing or something, it works just fine. Now, when I had Cutlass' and other vehicles like them with buckets and a factory center counsole, I was able to fit a megashifter in the factory counsole and it was okay. looked okay because you weren't using their cheap plastic housing, but they still aren't built really well in my opinion. In my 69 4x4, I've always really liked the column. Its quicker to get to low and back to drive also.
08-20-2013, 10:08 AM | #22 |
Formerly- 1972SuperCheyenne
Lokar or leave it on the column.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-20-2013, 10:31 AM | #23 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Leave it on the column with Lokar Linkage... Bucket seats...Go for the floor shift... http://www.lokar.com/product-pgs/shi...t-shifter.html
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 08-20-2013 at 10:42 AM. |
08-20-2013, 11:58 AM | #24 |
Old member
Why not go get a s-10 Blazer shifter console as I did. Looks good and lites up at night to know what gear your in.
Had a local guy build the sides for it. I like it. http://67-72chevytrucks.com/vboard/s...d.php?t=547110
04-02-2018, 01:35 PM | #25 |
i know this is an old thread but im wondering about the difference between lokar and the ratchet style shifters. Can the lokar go through gears just like the ratchet style? imo the lokar looks a lot better but the draw of having a ratchet style shifter is super cool
