Old 08-19-2013, 08:41 PM   #1
1966 chevrolet
327 out of 66 C10 Fleetside
We are getting ready to pull the Engine from the 66 and give it a rebuild.I haven't done any of this in over 20 years so I'm a little lost but have a friend for guidance.I am looking for a some power but want to keep it period correct,any suggestions?? Semi budget build,keeping the power glide if possible.Any and all help appreciated.Thanks,Chris
1966 chevrolet is offline   Reply With Quote
Old 08-19-2013, 09:11 PM   #2
jayoldschool
Moderator
Re: 327 out of 66 C10 Fleetside
A 383 stroker, with a good cam, nice heads, springs, rockers will look just like a 327 if you put the stock tin/paint colour/decals/air cleaner on it.
jayoldschool is offline   Reply With Quote
Old 08-19-2013, 09:21 PM   #3
61K10
61K10's Avatar
just rebuild your org. 327--one of the best sb chevy's ever. unless you want a hot rod eng (more power) replace the pg with a T-350 or a 2004r.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-20-2013, 12:22 AM   #4
Captainfab
60-66 Nut
Welcome to the forum
Just do a basic rebuild with some flat top pistons and a moderate cam with lift in the mid to upper .4xx and .050 duration in the 224 to 230 range. If the heads you have have the 1.74 intakes, I would look for a set of early heads with the 1.94 intake and 1.5 exhaust valves. A basic 4 bbl aluminum intake, 600 cfm carb (I prefer Holleys) a good HEI ignition, and headers and full dual exhaust. I would definitely swap the Powerglide for a TH350 or a 700R4.
Old 08-20-2013, 01:16 AM   #5
donthekawguy
donthekawguy's Avatar
Yup^^^ Better flow always helps. Don't forget hardened valve seats.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-20-2013, 11:36 PM   #6
Captainfab
60-66 Nut
You also might check out TX Firefighter's build thread. He built a nice 327 for his '63. There is a video in there too so you can hear how it sounds.
http://www.67-72chevytrucks.com/vboa...d.php?t=373970
