Driveline phasing
Hello Everyone
I got my motor mounts in the mail yesterday, and I plan on welding them in tomorrow. I have some questions regarding motor placement. I read this page, http://jniolon.clubfte.com/driveline...nephasing.html and it has helped, but I have a 2 piece driveshaft and I was wondering if the same rules apply. Also, how much could move the motor over towards the passenger side? I'm concerned if I line it up straight, the exhaust manifold will hit the steering box. What is your guys' experience on this? |
Re: Driveline phasing
Put 1 - 1.5 deg vertical angle into the first joint at trans. Set pinion angle to match front shaft angle. Second shaft angles will automatically cancel. Can do similar with horizontal angles / engine offset and carrier bearing position.
http://65.170.161.218/~spicerpa/site...stallation.pdf (Yes, there is a LOT of information there.) |
#3 | |
Yea right !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#4 | |
applies to steering universals too, borgsen has a great how to section on multijoint phasing.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Page 14 on the link 1project2many shows you what you need to know. Notice how the U joints and shafts are laid out so that the shaft never binds as it rotates.
That whole pfd is really good info that everyone needs to save in their Bookmarks tech file for future reference.
Well thank you all for the help.
I read through the PDF almost as soon as 1Project2many posted it. I have my motor mounts welded in. And I'll get to work on the trans mount soon. |
#8 | |
