08-20-2013, 02:39 AM | #1 |
Sloppy steering?
Is there a way to adjust the steering rack? My steering is sloppy and has too much play for my liking. My truck is a '73 with power steering.
Posted via Mobile Device |
08-20-2013, 06:26 AM | #2 | |
Re: Sloppy steering?
08-20-2013, 09:51 AM | #3 |
08-20-2013, 11:09 AM | #4 |
i need to try that, i dont expect too much. i also deleted the rag joint. trashing the old rubber bushings and installing energy suspensions bushings helped the most
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
08-20-2013, 11:53 AM | #5 |
How is it after deleting the rag joint?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
08-20-2013, 08:36 PM | #6 |
Have you checked your ball joints, tie rod ends, and drag link? If those are bad the steering will be really sloppy. Fought this on my 75 forever.
08-20-2013, 11:48 PM | #7 |
08-21-2013, 12:03 AM | #8 |
Is it too tight on either end now?
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer. |
08-21-2013, 09:15 AM | #9 |
This seems almost too good to be true...Is there any reason not to do it? What should a normal amount of "play" in the steering be?
08-21-2013, 01:55 PM | #10 |
The over center adjustment will only adjust the slop in the center of your steering. If its to tight it will normally cause the wheel to stick as you turn. This is usually because the steering boxes internally don't wear evenly.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
08-21-2013, 03:42 PM | #11 |
08-21-2013, 11:06 PM | #12 | |
At least that's what I've read before when I was investigating what to do. That said, besides being sloppy, my gearbox is leaking quite a bit from the input shaft - will likely replace with a rebuilt.
08-22-2013, 10:28 PM | #13 |
All I have to say is WOW!!!! That helped me out sooooo much!
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
