Old 08-20-2013, 08:02 AM   #1
nickbwilson
cold air intake setup`
anybody have any pics of there cold air intake setup or what kit works good with the 73-87 c10 trucks thanks
nickbwilson is offline   Reply With Quote
Old 08-20-2013, 11:04 PM   #2
Bigo Serge
Re: cold air intake setup`
This is my set up I used on my 72 Cheyenne. It isn't 73-87 but it has a very similar engine compartment. I used air raid kit from a 2008 gm truck with the Non-oil filter.
Hope it helps
Pick'em up, lay'em down, Oh Yeahhh
Bigo Serge is offline   Reply With Quote
Old 09-12-2013, 02:02 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: cold air intake setup`
Hope it helps
Sorry but that's not a true cold air setup. I don't want to make u mad but sucking in hot air from under the hood isn't what I would call cold air setup.
Here is my setup in my 1971 Chevy truck setup.
1990 Caddy air box modified by me. I first sealed the normal intake opening up which in the first picture has the sheet metal screw showing. I used gasket sealer also and then used a 4" hole saw to drill a nice opening in the bottom of the box. I then took a PVC coupling from lowes and cut the threads off but left enough pipe to attach the 90 elbow then took another coupling and cut the threads off of it. Took the 4" hole saw to the radiator support where the old V regulator was mounted and put the coupling through the hole to the other end of the 4" ninety. True cold air straight in from the grille area.
U can see the coupling in the support in this one.
U can see the 4" hole beside the drivers side head light.
All installed with K&N filter
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-12-2013, 07:58 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used parts form here, modified them for my needs, it would be MUCH better for your motor to actually get cold air ( fresh air) from outside your engine bay. good luck!
http://intakehoses.com/?gclid=CPzyyd...FWdjTAodz2KU0w
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-12-2013, 08:26 AM   #5
Bigo Serge
Nice work, looks like I'm gonna have to upgrade my system alittle bit. Thanks for the link on the tubing stuff.
