Old 08-20-2013, 09:48 AM   #1
C10Sim
C10Sim's Avatar
Does any body know where I can get this?
The front of my roof near the windshield is rotted out and needs to be replaced.
Through the inside I just ordered the whole inner roof panel so that should take care of that but I cant find that outter lip for the roof.
Does anyone make a patch panel besides the whole roof?
OR
Does anyone have an original cab that would like to sell the from part?
Picture attached.
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 08-20-2013, 11:50 AM   #2
dubie
dubie's Avatar
Re: Does any body know where I can get this?
have you checked GMC Pauls website. I'm not sure if they make a reproduction patch panel for that but if they do, Paul will have it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-20-2013, 12:01 PM   #3
Mac the Yankee
C10Sim,
I knew of two in a local salvage yard- will see if they are still there this weekend and get back to you.
Thanks, Bill (Mac the Yankee)
Mac the Yankee is offline   Reply With Quote
Old 08-20-2013, 02:11 PM   #4
C10Sim
C10Sim's Avatar
I have checked multiple vendors including GMC Pauls but no luck yet, unless I missed it.
Originally Posted by Mac the Yankee View Post
C10Sim,
Thank you Bill!!!
1968 Chevy Pickup
Old 08-20-2013, 04:50 PM   #5
Mac the Yankee
Do you need just the front half, or would you like the whole roof?
Old 08-20-2013, 06:20 PM   #6
mr48chev
mr48chev's Avatar
You would probably be better off to use the whole roof from a donor truck. I'd study the places that the roof is spot welded to the rest of the cab on the back side and cut the spot welds out while cutting the A pillers similar to how you would chop a truck but don't chop it. I saw either a thread on a forum or a magazine article showing how they had formed those pieces with a shrinker/stretcher setup but that takes some serious metal working skills.
If it were me I'd square the cab up as close to perfect as I could get it, align the doors perfectly so the gaps are right, brace the daylights out of the cab and then swap roofs and do what metal finishing needed to be done.
My ongoing truck projects:
Old 08-21-2013, 01:33 AM   #7
C10Sim
C10Sim's Avatar
I just need the front half or the front 10 inches of the roof. I will only be utilizing the little over hang that's about 3 inches. I want to keep my original roof and minimize the cutting into as less as possible. Thanks again for your help!!!
1968 Chevy Pickup
Old 08-21-2013, 01:38 AM   #8
C10Sim
C10Sim's Avatar
It cross my mind but since I'm going for the patina look, I don't want to change the originality of the color/patina. So I rather just patch that underside which should be hardly noticeable if done right but I sure do appreciate the suggestions.
1968 Chevy Pickup
Old 08-21-2013, 08:37 AM   #9
nhill
Some ppl remove the brow and work the roof down to the W/S .
nhill is offline   Reply With Quote
Old 08-21-2013, 09:56 AM   #10
mr48chev
mr48chev's Avatar
That isn't patina that's cancer. You don't fix it right and the whole truck will rot away in another few years.
Old 08-22-2013, 10:50 AM   #11
C10Sim
C10Sim's Avatar
LOL!!! That section is cancer but not the whole roof. Im going clean and acid etch the roof and apply POR-15 and I should have great access when I replace the inner roof.
1968 Chevy Pickup
Old 08-23-2013, 12:36 AM   #12
solidaxel
solidaxel's Avatar
Sounds to me like it is just right for a 1 1/2" chop on a new roof.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
